Results 1 to 13 of 13
Thread: ATTN:GSRteg
    95 Ecllipse GST
    clarkesville,ga
    Default ATTN:GSRteg
    JR your my new prision ***** !!!!!!!!!! :idb: lol
    1999 MITSUBISHI ECLIPSE GSX
    WORLDS FASTEST MODIFIED 4 CYLINDER
    OWNER: BRENT RAU
    4G63 YUP
    1400 HP
    2200 LBS
    11,000 RPM
    86 PSI OF BOOST
    MAGNUS MOTORSPORTS
    THAT IS 350 HP PER CYLINDER
    AND YES ITS A MITSUBISHI ECLIPSE
    1/4 MILE IN 6.97 SECONDS
    BRENT RAU'S MESSAGE TO OTHER DSM'RS:
    NEVER GIVE UP
    Quote Originally Posted by dcshoeco
    Why you say that?
    San antonio 210
    hes just goofing with u man lol
    Southside
    lol, did I start a chain-reaction...
    Quote Originally Posted by JDM_EK4
    Tony I got a question you know that engine light I told you about... well I checked it and at first it blinked 4 times then only 1 and continued only one. Now this means that its the o2. Cx only came with one wire o2 and the ex p28 came with 4 right! Now do I need to do a 4 wire o2 conversion and pin it in to the ecu. This is what I found out check it:
    Using a P28 ECU (and should work for most obd1 ecu's with 4-wire controls) Run O2 Sensor signal (white) To D14
    Run O2 Sensor signal Ground (green) to D22 (or any good Ground)
    Run O2 Sensor Heater Circuit
    Control (black) to A6
    Run the other black heater circuit power wire to (A25) or any good switched +12VDC source.
    San antonio 210
    he gonna have his ways with u.. bwahahaha
    Southside
    Quote Originally Posted by GSRtegŪ
    Run O2 Sensor Heater Circuit Control (black) to A6
    JR, I'm a lil tired , but try PMing Mr.Kidd and he's bound to have the answer. You can tell him that it was chipped for Uberdata, but then back to basic programing.
    Thanks.
    95 Ecllipse GST
    clarkesville,ga
    Why you say that?
    be cuz u have a cute lil mouth on ya boy lol..
    OWNER: BRENT RAU
    4G63 YUP
    1400 HP
    2200 LBS
    11,000 RPM
    86 PSI OF BOOST
    MAGNUS MOTORSPORTS
    NEVER GIVE UP
    Oh, **** your true color's come out...
    San antonio 210
    his rainbow colors lol
    95 Ecllipse GST
    clarkesville,ga
    lol if u say so..but wat color am i then lol??
    OWNER: BRENT RAU
    4G63 YUP
    1400 HP
    2200 LBS
    11,000 RPM
    86 PSI OF BOOST
    MAGNUS MOTORSPORTS
    NEVER GIVE UP
    Ur brown and proud lol...
