Results 1 to 32 of 32
Thread: Need help with air in my civic ! ! !
    San antonio 210
    Default Need help with air in my civic ! ! !
    I have a 1995 honda civic. The air dosnt work some times, once in a while it will kick in but most of the time it dosnt (not my AC).. i dont think it would be my blower motor, or i might be wrong? If this is'nt enough info just ask me for more. Reps for the ppl with good info and help.
    Lilburn
    get a new oneeeee duhhh :P lol jk jk
    *sigh*
    my civic is falling apart too...
    Fayetteville/PTC/Carrollton
    Quote Originally Posted by itsjustdee
    *sigh*
    Yeah my AC hasnt worked in a while..I have been meaning to take it out of my engine haha too costly to fix it
    Mad Scientist xb1's Avatar
    Athens, Ga
    so is there flow from the vents all the time, just no cold air, or is the actual airflow intermittent?
    San antonio 210
    Quote Originally Posted by xb1
    the AC dosnt work. but thats not the problem, no air dosnt comes out from the vents when u flip the switch (but some times it dose work)
    San antonio 210
    *sigh*
    Aman sister lol i do need a new car, im just swamped with bills and ****..
    Just another ricer
    Pennsyl-fuckin-tucky ya'll
    Probably the blower motor. I had to put one in my 91 Hatch. When I did, I pulled it out of my EF Sedan, but also did away with all the AC components as well.
    90% of teens say "oh shit" before a wreck. The other 10% are from Pennsylvania, they say " hold my beer and watch this shit."
    EvasiveEF9: Just fill me in...if it's black, I'm all over it...
    San antonio 210
    Quote Originally Posted by mxglory258
    yea i might as well change it. but it works once in a while so thats y i didnt think it was the blower motor ?
    Just another ricer
    Mine had the same symptoms. Eventually, after being able to tap it for it to work, it quit completely.
    San antonio 210
    how hard is it to change one ??
    about this far.
    have you tryed to get it re-cahrged? i have to do that to mine
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    San antonio 210
    Quote Originally Posted by callmetree19
    its not the ac im worried about. I took most of the ac stuff out, im worried about the air and blowing hot air for winter ..
    about this far.
    you have to go somewhere.. i think its like 30 or 45 to get it done..
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    Hwy 315
    It could be two things...
    1) climate control
    2) blower motor
    but before you go nuts and start replacing parts, look for loose connections. There should be a 2 pin plug on your motor, see if it's loose. There is also a wind force sensor on the fan housing with a 4 pin plug on it, the blower motor will not work without this.
    I've rarely seen a blower motor go bad because it's a simple device; your problem is intermittent, which makes me think that you have a loose wire or the climate control is your problem.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    San antonio 210
    Quote Originally Posted by CRXseven
    1) climate control
    2) blower motor
    -jonathan
    best help yet
    The Deep South
    also might be your ac switch, check that too. also, turn it on heat and if it doesnt work it is the blower motor.
    Yep... IDCoconut's Avatar
    Atlanta/Kennesaw
    I would start with your fan switch. Do you have a volt meter? If so, check if you're getting voltage to your blower. If not, it's definately just the switch. I'll putmy money on the switch.
    If it still blows once in awhile, then the blower is fine, power is just not getting there. If its cold when it does blow, then the system is charged and doesn't need to be charged.
    hell check your fuses, they always go bad lol
    Just another ricer
    1) climate control
    2) blower motor
    -jonathan
    Good call.
    Cactus. It was kind of a pain in the ass, had to pull the glove compartment, and to get everything to fit where it lines up is kind of a pain. More than anything alot of the bolts and screws were just a pain in the ass to get to. Hwoever, I didn't only change the motor, I replaced all the ducting under the dash as well.
    Good luck!
    San antonio 210
    Good call.
    Good luck!
    lol im gonna need it..
    college park
    get a integra=problem fixed!
    no sounds like your blower motor thats what happened to my dc when i first got it
    now with LSD
    Athens, Ga
    Did you take out the ac evaporator next to the blower? Sometimes lots of crap gets stuck in the evaporator core fins and blocks airflow. I cleaned mine out (nasty as hell) and found entire leaves in there. That may be part of the problem as well, but I'd say blower wires are likely the cause as well.
    San antonio 210
    thanks for the help.. didnt think of that
    Cambodia
    I would check connections as well. It might also be the blower motor relay, which is located in the fuse box under the hood. Try switching it out with the horn relay and see if the problem is still there. I think the blower motor relay is the one in the middle of the three relays? If I'm not mistaking, I think the blower motor is only held on by 3 screws that you could get to from under the glove box...
    San antonio 210
    Quote Originally Posted by iNsTuN nOoDoH
    thanks man, i'll check it out..
    Its the blower motor bro. But if you really want to test it when it doesnt come on.... let the passenger kick the blower motor and if it start then you know.
    JDM TYTE AnthonyF's Avatar
    i'm kinda confused...the AIR as in...the Speed of the air knob? Check ur relays. Sometimes they like to go in and out. an easy way to check (half ass way) tap on them see if the air turns on, also possibly a short like i'm sure some1 else has already stated.
    if u cant fix it...stick ur head out the window
    The Carbon Fibered R6
    Geogia
    go under the dash and located the blower motor, and find the harness wire and mess around with it, i had a situation like this too...all i did was flick the wire here and there, and it started blowing.....or check out the relays too......!
    Certified Gearhead Pavlo's Avatar
    Alpharetta
    Check if you are getting voltage to the blower motor when it's not working (might be hard to find that moment, and have a volt meter ready lol). If you have a +, but no -, then it is the blower motor resistor. If you have both +, and - then it is the blower motor. If you aren't getting **** then it's either a relay, or a bad connection somewhere; or possibly the actual switch at the climate control panel.
    Representing VWs.
    Jonesboro/Stockbridge
    1) climate control
    2) blower motor
    -jonathan
    I was thinking this same thing. That his wires or loose or something came loose, since its working once in awhile and sometimes it doesn't. But I don't know, I never messed with blower motors.
    San antonio 210
    any one have a diagram ? i'll rep u !
    Athens, Ga
    hold on ill get one for you
