Results 1 to 22 of 22
Thread: My EF cutting off on me
    Jonesboro/Stockbridge
    Default My EF bogs...
    Alright my car is being real stupid now, now I got it idling smooooooth. No rocking back and forth or anything. We put a z6 manifold and throttle body on it. But now, when I step on the gas it just sounds like it bogs out and it even cut off one time when I stepped on the gas. It just died on me...
    Also it makes stupid popping noises again from the intake manifold...
    I really can't figure what the hell is wrong with it. Anybody with some info let me know please?!
    Anybody?
    Senior Member Nang's Avatar
    check and see if your axles are all the way in
    problem 2
    Quote Originally Posted by Nang
    problem 2
    Do you mean all the way in the tranny? I think they are...shanked the **** out of them when I put them in. I know one side is..the driver side one is...and the passenger side looks like its in, but wouldn't it leak oil if they weren't in all the way?
    Hiram/Dallas area
    does the car bog when you rev it suddenly?
    look for vacuum leaks.
    does the car pull at all when you let out the clutch? a simple test to see if your axles are all the way in the differential is to jack the front end up so both wheels are off the ground, put the tranny in gear and spin one wheel, the other one should move in the opposite direction.. unless you have a limited slip differential.
    Quote Originally Posted by 2rotor
    Oh yeah, I did that...and that happened when I was trying to put the lug nuts back on. And ummm NO, the car doesn't pull at all when I let off the clutch. Like I'll be at redline...and I barely picked up ten miles an hour....
    well if your at redline and your only going 10 mph then your clutch is fried lol
    Foo! You da one who put the clutch in! Why didn't you just put the other clutch in like I said. Sigh...retard. You wanna come change my clutch then. Cause you know I'm lazy. I don't like doing anything with trannys neither
    Bump...need help on the new situation...
    random guy's pops!
    random guy's moms cornhole!
    sooooooooo , you now need help replacin the clutch?
    dnwp
    Quote Originally Posted by EF/EG_Scotsman
    if i do have to replace the clutch then I don't NEED help...I'd like it because I get bored by myself. Lol
    Anybody got an idea besides the clutch?
    Hwy 315
    check your adjustment cable
    hit up the parking brake to hold the car still, then act like you're driving it... put the car in gear and let the clutch out...
    does it kill the engine?
    does the engine just bog down, but keep running?
    If it's the second option, then you need to replace your clutch.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    get on level ground, throw the car in 5th gear and try to take off. if you stall your clutch is good, if it just revs up then its pretty much gone
    Lol it does that in first gear....even if I rev up to redline and try to launch in 1st...its just bogs out and stalls....
    LAWRENCEVILLE
    sound like a clutch or the ajustment. Also with your cutting off problem are you sure you got the ground strap tight when you fixed the thermostat?
    Quote Originally Posted by silversol
    Yeah the ground is on...I have no problem with that anymore. The car stays on and idles smoothly. But now I just can't get it to go...I think I'm gonna try and put my other clutch on....Sometime later when I get bored during the week.
    bump with new problem
    Low-n-Slow iEvo's Avatar
    Gnett
    yea turn the car on and then get like brake cleaner or somthin and spary it around the intake manifold......if it bogs then its leakin. if not then ur good on that side
    Quote Originally Posted by BlackIX
    Thanks...I'll try that next!
    Southside of The Jungle
    adjust your clutch cable where does your clutch engage at like if u let it out slowly with out using the gas does it move
    Yeah I figured out the problem though. Thanks. Haha.
