Results 1 to 23 of 23
Thread: 1jz vs. 2jz???
    ☠gOOn☠ Brian*'s Avatar
    ☠Young Harris☠
    Exclamation 1jz vs. 2jz???
    I know there is .5 of a litre and a few hps but i can afford the 1j LOL
    Its going in my 91 MKIII Supra btw
    Id wait to afford the 2jz, can handle alot more power
    Lexus GS300
    very expensive swap to do it the right way.
    wiring harness is 3 feet too short, needs a radiator, some kind of tuning system, walbro, headgasket for any serious power.
    Supramania.com would be a better place to research and ask.
    Never mind.
    ☠Young Harris☠
    Thanks man, I got a fluidyne radiator, I am going to get the AEM ems (depending on which motor I get), already have 355 fuel pump... Headgasket I would like to get lol, and the harness (can I get one from anywhere already done???)
    ☠Young Harris☠
    Quote Originally Posted by SL33P3R
    I'm prob going for 450-550hp... Think the 1J is good for it?
    I'm new at yodas, usually building easy ass honda motors lol
    i believe horsepowerfreaks.com sells the harness for like $1000 already done.
    Certified Gearhead OnyxHatch's Avatar
    North GA
    Compomise....do a 1.5j.... 2j bottem w/ a 1j top. in fact..you can buy one already made...just contact boosted1jz he's sellin his mark III w/ the 1.5j and a big ass GT40-82 turbo for 8,500
    -Carlo
    2004 Volvo S60R
    Quote Originally Posted by Nick
    Or the Supraforum.com will answer all you questions. 1jz will handle the power your looking for. The highest whp 1jz is around 800.
    Banned SE-Rious1's Avatar
    WINDER,GA
    ive herd from a few peps lately that there 2jz's are tearing up alot more the eternals arent great for the money you spend
    there have been a few blown up 2JZs here lately true. but the 2j is far superior to the 1J IMO
    stock vs stock
    Alot of the 2j you hear about locally are older motors out of the aristos. Mileage and condition isnt exactly always as good as the USDM motors
    Also any motor can let go from any make.
    villa rica, ga
    stock vs stock
    this man speaketh the truth!! whatup bro?!?
    MabletonSpeedShop member
    MCE Mafia supporting member
    honored to be MCE Dec'08 rotm
    Untouchable Tank's Avatar
    Honolulu
    Quote Originally Posted by SLYDWAYS240
    IF , properly installed and tuned right you wont have any issues out of a 2JZ with serious HP. As far as the 1jz is concerned for the horsepower range your looking for the 1jz should be fine. I would suggest you do some research on Supraforums.com or ask a shop that KNOWS 2JZ/1JZ MOTORS AND SUPRA INSTALLS . Also do alot of research on which shop does your install and youll be fine. I just had my Motorwork done by AAP and they did SOME OF THE BEST work i have seen to date, no issues what so ever i picked my car up and havent had a problem with it at all, you can call them with any questions you may have .
    PM me if you need the number
    Quote Originally Posted by NevrNufTorq
    nothin much man just trying to get stuff done before SEMA.
    you going to ISD? good luck to ya'll
    Barrett Parkway, GA
    Quote Originally Posted by 2turbo4u
    maybe in the area...but there are alot more making more than that
    the problem with 1J an 2J motors is that they are usually over 10 years old.
    90% of them have been sitting on a dock or at a salvage yard for YEARS.
    Most poeple dont think about that when purchasing a motor, sure low mileage is a plus, but if its sat for 10-15 years, seals are rotted, rust, water pumps seize, headgaskets blow or deteriate, etc.
    the really GOOD JZ motors are $$$, so just be carefull where you get one from, a GOOD 2JZ is $3000+
    a GOOD 1JZ is $2000+
    Barrett Parkway, GA
    ^^^indeed ^^^
    ☠Young Harris☠
    man, thank everyone of you for your help. I don't know if you have heard of Vision Performance??? they are a local shop up here in North Ga. They just got a guy named Glen who is a 1j-2j/Rb "expert" so he says... I might have him do the wiring, the 1j that I am looking at has 40k a 6 puck clutch, light weight flywheel, new water pump... ext....
    REPS are being handed out!!! thanks again guys
    Vision Performance is cool! tell Ron i said hi
    ☠Young Harris☠
    will do!! he is a bad ass
    1jz is cool... Change to the 2j Coils (change the clips) Upgrade the head gasket.. Recoment the Sard injector's... If you have to stay with the Ct12's then upgrade them to the Austrailin Ct12's there steel wheel.. ..Also your gonna want to use a FCD and Speed limiter...
