Results 1 to 14 of 14
Thread: b16A2 HEAD BUILD???
    YEAH! bRiAnMcIvIcS's Avatar
    Default b16A2 HEAD BUILD CHECKLIST...
    I'm gonna build the head i just want to make sure that im not missing anything. If you guys could tell me anything else I need that would be awesome. Im gonna build the block also but not yet, im just gonna do it in steps. Is anything missing?
    • SKUNK2 STAGE 1 CAMS $470
    • SUPERTECH VALVES $200
    • SUPERTECH VALVE SPRINGS $130 CHECK
    • SUPERTECH Ti. RETAINERS $130 CHECK
    • SKUNK2 INTAKE MANI $200 CHECK
    • SKUNK2 T. BODY 68MM $230
    • SKUNK2 CAM GEARS $160 CHECK
    • SUPERTECH VALVE GUIDES $85
    • SUPERTECH VALVE SEALS $50 CHECK
    • CAM SEALS $20
    Jonesboro/Stockbridge
    Quote Originally Posted by bRiAnMcIvIcS
    • SKUNK2 STAGE 1 CAMS $500
    • FERREA VALVES $200
    • SKUNK2 VALVE SPRINGS $170 CHECK
    • SKUNK2 Ti. RETAINERS $160 CHECK
    • EDELBROCK T. BODY 65MM $300
    • SKUNK2 CAM GEARS $150 CHECK
    • FERREA VALVE GUIDES $100
    • FERREA VALVE SEALS $50 CHECK
    I think thats everything...I think you should get the big Skunk2 Billet Throttle body though...heard they're pretty good and they're like 50 dollars cheaper than the Edelbrock.
    Quote Originally Posted by JDM onlyy
    with all that head work man why not go w/ a 72mm TB??? i forget who makes them Kidd knows probably
    EF SQUAD FTMFW!!!!
    Quote Originally Posted by SL65AMG
    Oh yeah, thats what I meant to say but I forgot to say what size. Lol
    "big $hit poppin"
    in the slums where killas get hung
    sounds like your gonna get some good head
    LMAO! Hell Yeah!
    Southside
    Have you looked at any other cams rather than Skunk2's?
    not really, everyone says skunk2 makes the best camshafts. I also thought about ITR cams, but with the skunk2's you get more bang for your buck.
    Southside
    Well mainly because the price, but there are more aggressive cams out there other than Skunk2's, there's Crower, Buddy Clubs, and the list goes on, but if you want power do the research yourself and not try to what everyone says cause not everyone is running an all-motor setup and different factors apply, do what you feel like is good for your setup not what everyone feels like you should do.
    turbonetics
    is that what iam looking if i was to built a gsr head ...
    dfafa
    yeah pretty much.
    Warner Robins, GA
    buddy club makes some badass camshafts too. you might wanna take a look at those. i think blox makes a 70mm throttle body and it's only around 170 brand new off ebay.
    IA Member jbhondatech's Avatar
    Before you sink the money into valve guides you might want to make sure you need them. If the guides are not done 100% correctly the head will be garbage. If your going to spend all that money to do an NA build buy bigger cams than stage 1 you will not be happy with them.
    It's not a N/A build it's for turbo. whoops, probably the wrong section, my bad guys. Im gonna build the head and then toss my b16 block and get a b18c and resleeve it to 84mm then put in cp pistons 10.1 compression, eagle rods, arp headstuds, type r oil pump, acl bearings, etc. That should put out some decent power before the turbo. What do you guys think???
