Thread: j-body Boosting....?? Question needs answering...
    SuperLIGHT SUNfire.. madking411's Avatar
    Norcross
    Default j-body Boosting....?? Question needs answering...
    I got this list from j-body.org, and its about how to build a custom turbo kit for my car's engine. Does the list look complete? or are there other parts on the side that i should know about?? I think im going to take ~a year + or - to try to save up the money to get all the parts for a custom turbo, or buy a turbo kit...
    Oh, and i've heard that you can take a turbocharger off of a Volvo from the junkyard, and get 4 or 5 psi...is this a good starting point? or what??
    Heres the list:
    Turbo (generally a T3 or T3/T4 will do)
    Wastegate (Internal or external)
    Manifold
    Turbo downpipe Flange
    Bolts for turbo and downpipe flange
    Downpipe
    Braided oil lines with fittings
    2.5" Pipe for charge pipes
    Connectors and clamps for pipes
    BOV and flange
    FMU (I'd go cartech adjustable personally)
    Bigger Injectors (if you plan to run over 6lbs of boost)
    Inline/In tank pump
    Boost controller (I'd go Greddy Profec)
    MSD-DIS 2 (To turn back timing if you want anything over 6bs really)
    TB Plenum
    Lots of misc vaccum hose
    Rubber Fuel lines for FPR
    Oil and oil filter (for the obvious reason)
    Gaskets
    Gasket sealer
    Air filter
    Intercooler (optional, but worth it)
    Some spare metal brackets for custom mounting the Intercooler
    Misc bolts (self tapping), and Nut/bolt combos
    Gauge pod
    Boost Gauge, EGT gauge (optional but smart to have one)
    (If you have a profec boost controller the boost gauge is unnecessary as its built in)
    \\\ATLANTA~ATNALTA///
    Dec 2003
    Yeah it really depends on what you want out of it. It you want a safe daily car.
    mani
    t3 turbo
    downpipe
    bov
    internal or ex wastegate (5-6 psi)
    intercooler
    piping
    255 walbro
    fmu
    of course all you bolts, fittings, oil feed and return, tapped oil pan.
    missing link
    If you wanna get serious
    Injectors
    engine manage
    tuning
    and plenty of other stuff
    You can find a garrett off of a saab, volvo, or mercedees, they work good for 4 cylinders.
    this guy should be able to help you out http://www.myspace.com/spyderwizard
    Just do a little searching, but be careful. I have done some looking around on the ecotec sites and there are PLENTY of people full of miss information.
    MAINSTREAM PERFORMANCE
    Digital Box Tuning
    Norcross
    Quote Originally Posted by rickylsi
    mani
    t3 turbo
    downpipe
    bov
    intercooler
    piping
    255 walbro
    fmu
    missing link
    Yeah, i want a safe daily car that can bite HARD when i want it to.
    Whats the missing link...??
    Blacc Panther member
    look to ya left
    how do you know chazz?? yeah he's the mad scientist.. if he cant figure it out it cant be done to our cars lol.. yeah you need any help hit me up or hit him up...
    Quote Originally Posted by Dracc
    hes a good friend of mine. do you know jeff also, he had a white turbo cavi a couple years ago
    look to ya left
    do i know them.. they are like my family lol.. i got jeffs wheels on my cavi now lol small world
    Norcross
    Hahha okay then, that sounds good. Im not REALLY ready for turbo-ing yet, but...im planning on doing it sooner or later. Just doin some good research now
    Quote Originally Posted by madking411
    A missing link is something that you do not need, it is a POS. All it does is bleed off pressure before the map sensor so it doesnt "read boost", or more pressure then the sensor can handle before it goes into dummy mode. If you are serious about boosting then you should get the map sensor from the SS, its a 2.5 bar map.
    Digital Box Tuning
    Gigity! COGCaviZ24's Avatar
    Gainesville
    yeah, chazz is awesome, it's too bad he has decided to sell his car.
    this is offically the 1st the j-body related thread that not bashing j-bodies on this forum.
    AIM & Y!: CogcaviZ24
    The ecotec is a badass motor, its just a shame that GM cheaped out on the crank and some other things. They should have put a crank in it that will support the 1450hp that their drag cars are making and a tranny that will hold it without having to swap to a different model. I am in the honda community, but I am impressed with the ecotec. Its just hard to beat a motor that can hold 400+ hp in stock form that was NA to begin with, and hold over 500whp on the stock sleeves with just pistons and rods reliably. Lastly a stock crank that support 1200whp and its from an engine that was originally NA and not designed to make that power. The Sleeved block from chevy is $2700, the race crank thats in the drag cars is $3500!!!!!!!!!!!!! The race head, and some other mics things thats not even enough to put a running built motor together is over $6k and that doesnt include a turbo kit , ignition, tranny, or fuel.
    I really want to build one, but its just too much money.
    Digital Box Tuning
