Results 1 to 40 of 77
Thread: Real hp out of SOHC motor... possible?
    Keeping to the right w3bcod3r's Avatar
    Stockbridge
    Default Real hp out of SOHC motor... possible?
    Is it possible to get some real hp out of a SOHC motor... and if yes what would you do...?
    JDM = Just a Dumb MotherFu**er...
    stock motor you can get 220-230 out of the VTEC engines
    Non Vtec 180-200 is more realistic
    they are fun cars if you do the turbo kit right an keep the turbo small!
    Quote Originally Posted by w3bcod3r
    Don't you drive an accord? Whats "real hp"?
    Boosted f22 will net you more power than a d.
    Thread on h-t about boosted f22
    http://www.honda-tech.com/zerothread/1657517
    Texas
    F is stronger then d. What Mike said about the motors on power in a d series is a lil high. 220 to 230 damn. That shit will blow up!
    I am Montage
    Augusta, GA
    why do so many people underestimate the D series? look on other sites and they make 300+ all day with built bottom ends and stock heads.
    thats about all u need for a fast driveable daily
    300+ d series dont last... i can show you...
    Casey made 285hp for about 30 minutes total.
    ***Lotus Elise***
    BlackWatchRacing
    Not a completely true statement. i know of d17's that have over 300whp for atleast a year. Granted they are built, but they are still d series.
    IA MEmber
    Dezod has a 370whp D17
    IA MEmber
    Gaining 350+ whp in a D17 EM2 would cost upwards of $10,000 or more w/ no sponsor hookups and having a shop do all of the work.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    I knew his name would come up sooner or later
    Jonesboro/Stockbridge
    I knew a dude that made 280whp on a stock block and head....blew it to hell when the boost upped itself..Lol. Shit was pretty funny...he'd doing it again too....stock internals, only with a d16z6 this time. Before it was a Mini Me
    Texas
    Been there done that. You wont even make 230 whp on stock internals for long time. You need to build and dont try to up boost past tune. Not worth it.
    Stockbridge
    See thats the whole thing... i don't have time to bore the motor out or replace any critical parts for that matter... turbo or supercharger???
    Whats the max psi would i be looking at anyhow... and no, im not expecting 20 ... maybe 13-15... sounds real or what?
    You should be more concerned in mow much power you are going to make rather than how many psi your turbo is going to be pushing.
    You should do some more research before you boost your motor. Or just take it to a shop who knows what they are doing.
    This would be a great stock block street setup..
    Quote Originally Posted by bigdaddyvtec (from H-T)
    im the guy cd5 jeebies was talkin about with the t 3/4 on the accord. Its a t3/04e 48/60 with stage 3 57 trim wheel.
    The 63 hot side is cool but WILL spool later. Ive got full boost by 33-3500, and it pulls like a train til redline. With all the new upgrades, im sure it will be even more brutal. Its GREAT on the street. i thought about running the 63 hot side, but decided against it, besides the stage 3 wheel in a 57 trim spools PERFECTLY in my EXPERIENCE...ask fatty.... he was grabbingfor shit to hold onto when i took him for a ride in it the first time. LOL
    Stock block at 10 psi on a conservative tune got me 260 whp/270 tq. Car has run 13.89 w/ shitty 60 foots (2.3s), subs, PS, A/C, im fat, full interior on 17s.
    Motor had 140000 on it when i boosted it. Ive BEATEN it for 6-7 months and around 20000 miles. I got a coolant pushing sit. goin, so i pulled the head, and the motor (sleeves-valves-pistons) still look really good. Tossing in some ARP head studs, new HG, got my exhaust mani ceramic coated, designed and built a new downpipe (coated and wrapped). 3 bar MAP, and a new tranny (H-23 for the shorter 2nd -5th gears). Not to mention the DELTA cam (hopefully it will be done thursday). Retuning for 13-14 psi, looking for 300+ whp on conservative tune
    Texas
    Thats different from a d series. That guy is runnin a f series from what it sounds like. I you will not make that on a d series at 10 pounds. I run 10 on a 1.5 D and I make 207 and 195. My friend runs a f series and runs 7 pounds and makes 220 and 216. All of this is on a Stock Block.
    Quote Originally Posted by LiLJames93
    I know its a f series. I think the op drives an accord.
    Texas
    gotcha!!!!
    raggedy volvo owner
    Tigger made 374hp out of a built d16 running 18psi. Just takes the right parts and setup.
    the ford guys put down 500+whp all the time on SOHC and the volvo guys are making 400whp+ easily on SOHC.,
    My car is factory....
    Every single performance part and or modification it has was made in a factory somewhere.
    Privateer Racing!!
    Duluth,Ga
    Rota92 on h-t made 568 HP Single Cam @ 34 psi. His dyno chart
    D16z6
    GT3567R .82
    34 psi
    Dynapack dyno
    BK ALL DAY
    ^^^now thats some sick shiy right there
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    Quote Originally Posted by B18c1Turboed
    D16z6
    GT3567R .82
    34 psi
    Dynapack dyno
    Ummm WOW!!! Thats the shittt right there...I want that engine and set-up.
    Texas
    Not a bad way to spend 10,000.
    Full Race had a single cam D that put out 500+ hp with stock sleeves
    Certified Gearhead bernard's Avatar
    J-ville FL. FR. O'side Ca.
    460 on stock sleeves but built bottom end. For a cheaper setup for the sohc. Run the vitara pistons and scat rods. And good rings. and block guard. Ported and polished head. Your good for some good numbers. The rest depends on you. Turbo kit, injectors exhaust. All has life in your hp numbers. Good luck on your decision.
    140 on one wheel
    columbus, ga
    Quote Originally Posted by blue_5g_zc
    actually d series vtec stock heads are good for 400whp all day long. You could tear open a d16 throw in 150 vitara pistons a set of tuner toy rods or eagle and basic oem stuff and put down 400whp with ease with less then a grand in your motor. And it would be SAFE if tuned right! There's a shitload of d16's on H-T putting down over 400whp on stock sleeves with vitara pistons. 500whp range with cp's and je's on sotck sleeves.
    Penthouse
    never knew hp and d-series could be used in the same sentences
    Stockbridge
    shit up top ^^^ is fucking sick!!
    Quote Originally Posted by C_R_X
    I am with you...
    BeFF <beef>
    GECKOSQUAD
    cravin a s2k
    Cookeville, Tennessee, United States
    right now on hondatech is a bone stock d16z6 with arp headstuds and a cometic headgasket making 400 to the wheels in an AWD ef hatch.
    http://www.honda-tech.com/zerothread/2104408
    220 - 230 is not pushing it on a stock d-series bottom end. whoever said that needs to keep quiet. i pushed mine to 300 before i built it. now im going for the 400 mark with pistons and rods and thats it.
    its all in the tune! sing it with me!!!
    My friend's 02 Mustang GT SOHC made 400RWHP and 400RWTQ with a Vortec SQ-trim blower at 9psi.
    SOHC cars can make power - you just need to get the heads to flow!
    >> 94 Dodge Stealth - Slow
    >> 94 Dodge Stealth
    cravin a s2k
    so are we talking about sohc hondas or sohc motors period????
    D16z6
    GT3567R .82
    34 psi
    Dynapack dyno
    and he doesnt make over 250whp till 6000+rpms. talk about LACK of a powerband. He would get WALKED on by a 250-260whp GSR with a t3 Super 60. He jumpes 250whp in 700rpm, all he is going to do is SPIN
    TO the guy saying 300whp is easy on a stock motor, you are 1 of a million that had a motor stay together past 250whp on a stock D series bottom end.
    Anyone LOCALLY that has made over 350whp BLOWS UP. They arent made to last. I only know what i have seen and tried.
    Turbo D series on a stock block are good for 220-230 with VTEC and 180-200 NON VTEC. anything past that, be prepares to build or swap the motor withing MONTHS. IT WILL BLOW UP, you can have Jeff Evans tune it, it still wont last.
    Your asking a 80whp-120whp motor to make double or triple what it came with from the factory.
    Dont believe everything on Honda-Tech or on the internet.
    you just shattered all my hopes and dreams
    Privateer Racing!!
    Duluth,Ga
    Mike,if you dont read it or see the car, Dont belive it hasnt been done, there is a certain d series making over 350Hp locally.He has been making that power for over a year.
    STOCK BLOCK?
    ok there is 2 out of a million
    Privateer Racing!!
    Duluth,Ga
    STOCK BLOCK?
    Naw piston and rods, thats all!!! i think!
    Just do it. LOL!!! Everyone learn from the experience. Give it a shot.
    So w3bcod3r..... are you going to boost your accord or not??
    Privateer Racing!!
    Duluth,Ga
    If any of you guys wanting to do D series motors, I have two fully Built ZC motors, JG sleeved ,CP pistons and rods for sale!!!
    Motors where assembled by JG in california, with there sleeves and all!!! One ZC is a 1.6 and one is a 1.8.
    I tought i would throw it out there!!!
