Results 1 to 5 of 5
Thread: boosted b18c in 95 civic hatch
    Default boosted b18c in 95 civic hatch
    quick question what do i need to go about boostin my stock b18c and how do i run the oil feed line and return just let me know and its done.
    honda-tech.com
    Privateer Racing!!
    Duluth,Ga
    If you have to ask, DONT DO IT!!!
    HAve a shop do it for you, or you will regret it when u do the return line wrong and u burn up turbos!!!
    02 WRX patrick4588's Avatar
    warner robins
    buy a oil filter sandwich adapter for the oil feed line. run the feed from there. the drain goes from the turbo into the oil pan. you will need someone to tap your oil pan for you.
    GCO Member
    NRA Member
    warner robins
    i suggest buying a turbo kit since you dont have a lot of knowledge on the subject. If you plan on doing it yourself, then you need to do a lot more research. Full-Race.com and cheapturbo.com have some awesome kits if you choose to go that route.
    GCO Member
    NRA Member
