Results 1 to 13 of 13
Thread: can anyone name this car reps to the first one
    R.I.P Leisa USMC_is300's Avatar
    north alabama
    Thumbs up can anyone name this car reps to the first one
    Performance
    Acceleration: 0-100 km/h (0–62 mph) 3.2 seconds
    Top speed: 395+ km/h (242+ mph)
    Standing quartermile: 9 seconds, end speed 235 km/h (146 mph)
    Braking distance: 31 m (100–0 km/h)
    Lateral g-force: 1.3 g
    Fuel consumption: Highway travel: 13 l/100 km
    Combined: 17 l/100 km
    Body
    Two-door, two-seater with removable hardtop stowable under the front boot lid. The body is made of preimpregnated carbonfibre/kevlar and lightweight hard-foam sandwich reinforcements
    Dimensions
    Ground clearance: 100 mm (3.9 inch)
    Fuel capacity: 80 litres (17.6 gallons)
    Luggage compartment: 120 litres (26.4 gallons)
    Dry weight: 1180 kg
    Aerodynamics
    Cd. 0.297. Frontal area 1.825 m2. Completely flat underside of chassis. Venturi tunnels at the rear of chassis/body
    In standard mode the car is very well equipped with many items that competitors have as options. Many customers, however, want to further equip the car. Therefore we can offer a list of customer options which should fulfil every demand.
    Standard equipment
    Aluminium rear light casings
    Detachable roof panel
    Climate control
    Electric rear view mirrors
    Leather interior
    Central locking
    Electrical windows
    Alarm with immobilizer
    Toolkit
    Driver side airbag
    Power steering
    Hydraulic ride height control
    Servo assisted brakes
    ABS
    Traction control
    Stereo with CD-player
    Tyre pressure sensors
    Car cover
    Customer options
    Custom Color Leather Interior
    Custom Paint Color
    Parking Sensors
    GPS Navigation
    Sequentially operated gearbox
    Rearview Camera
    Fitted Luggage
    Chassis
    Semi monocoque made of preimpregnated carbonfibre and with honeycomb reinforcements for added stiffness.
    Front and rear suspension: Double wishbones, adjustable VPS custom racing shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.
    Brakes
    Front brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
    Rear brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
    Wheels
    Koenigsegg magnesium alloy wheels with centre locking.
    Front: 19” x 9.5”
    Rear: 20” x 12.5”
    Tyres
    Michelin Pilot Sport 2. Unidirectional with asymmetric tread pattern.
    Front: 255/35–19” (Y)
    Rear: 335/30–20” (Y)
    Steering
    Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres
    Engine
    Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
    Displacement: 4.700 cm3.
    Compression: 8.6:1
    Weight: 215 kg
    Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.
    Oil: SAE 10W60 fully synthetic racing.
    Oil tank capacity: 12 litres (2.64 gallons)
    Induction system: Sequential, multipoint fuel injection. Dual Rotrex centrifugal compressors with 1.4 max boost pressure. Intercooler.
    Fuel: 98 RON unleaded.
    Ignition system: Direct coil on plug. Transistorised.
    Power output: 806 bhp at 6.900 rpm.
    Maximum torque: 920 Nm (678 ftlb) at 5.700 rpm.
    Maximum rpm: 7.600 rpm.
    Transmission
    Specially developed 6-speed gearbox by Cima. Incorporated internal oil pump and oil cooler. Torque sensitive, limited slip differential.
    Clutch: Dual Plate, organic or cintered Ø 215 mm (8.46 inch). Oil-cooled and electronically operated.
    itakepictures
    changaroopouch
    koenigsegg ccr
    north alabama
    damn i thought that would be hard guess not lol you know msrp on one
    +1
    Kennesaw, GA
    Quote Originally Posted by TurboRS
    +1
    more than you can afford pal, Koenigsegg.........
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Wo you have to be kidding me anyone wHo doesnt guess that instantly is a we-tard. THAT CAR IS GOD
    rockin' the double M's
    l'ville,ga
    the front plate says "ccr"
    Smyrna
    Quote Originally Posted by yerrow
    Yeah, that doesn't give it away at all.
    the land of race car ya-yas.
    well dang...
    all this time i thought it was a civic.
    nah son, accord. lmao
    livin again collins's Avatar
    chillin in the sloooo gtoooo
    damn thats one helluva wide body kit!
    bumble bee ... the transformer...
    Also you wrote the name infront of the wheels.
    Smyrna
    Quote Originally Posted by KDM guy
    well dang...
