Results 1 to 22 of 22
Thread: Computer Boot times (nerds only)
    Default Computer Boot times (nerds only)
    How long do your computers take to reboot, I just realized how quick mine actually is. State whether it's pc or mac.
    PC here
    I just did a full restart, including closing open programs (trillian, firefox, and PS CS3) I logged in and then fully booted (all background and start-up programs done loading) in under a minute, my steering wheel used about 15 of that to align itself (boot stops for some reason when it does that). Holy shit.
    - IA Mgmt
    h series
    norcross
    i don't know the exact time, but i have a mac and it reboots in under a minute too.
    decatur
    it depends i have 6 computers at home, the fastest one i clocked at 42 seconds. and i am not talking about ones that you just made. (those boot the fastest)
    Quote Originally Posted by wantboost
    Me either I only have 10gigs left on my hard drive, hell I still run a GeForce 6800 in mine.
    - IA Mgmt
    Used to be real fast easily under a minute. But every now and then when I go to start it again it doesnt fully boot up, so I cant open anything, but I see the main page. WTF, nerds what shall I do.
    ***Lotus Elise***
    BlackWatchRacing
    Mac right? Just put it in sleep.
    - IA Mgmt
    h series
    norcross
    would there be any difference if you ever turn the computer off if you have a mac? say i left it in sleep all the time and never rebooted it would it be the same?
    decatur
    the 6800 ultra?
    the 6800 ultra?
    No, just the 256mb PCI-E 6800
    Quote Originally Posted by an0therh22
    From what I've heard you can do that for more than 6months with no slowdown.
    - IA Mgmt
    Yeah it's a mac. It performs fine if I just let it sleep, but if I do that it gets hot as hell when I'm carrying it from class to class. So I have to turn it off a lot.
    ***Lotus Elise***
    BlackWatchRacing
    Sarcastic Asshole fivex684's Avatar
    Jefferson
    About 90 seconds.
    Opteron 170 @ 2.6 Ghz, 2 gig's and Nvidia 7950 GT thats the important stuff.
    PRO desi
    In my car 'round town
    usually mine is under a minute too.. however QUESTION, my computer just messed up last night and no longer boots up all the way.. I get the ASUS screen...and right when the windows XP logo is suppose to come up it goes blank... im tryin to hit safe mode but it wont allow it. ne ideas? and no i dont want to reformat, its a pain
    Norcross
    The system configuration utility is accessible by selecting Start > Run > Type “msconfig” then press enter. Now you can control how you want windows to start. To begin, select the BOOT.INI tab. I won’t go into the details about tweaking all of the options as there are downsides to some. But one option that can be changed with very little downside is the Timeout. The timeout box allows time for an OS loader to give choices to the user. Usually this is for selecting a recovery console or for a dual boot system. In any case, the timeout is the number of seconds that windows will display the message. So setting the timeout to 30 means that the message will be displayed 30 seconds. So if it is set on 30 now and we switch it to 3 seconds, which is ample time to press a key on the keyboard for most users. And we cut our boot time by 27 seconds.
    PRO desi
    however i cant even make it to the desktop.. so i couldnt even get to the "start-->run." i cant even make it to the XP splash screen that has the bars running across at the bottom
    IA Member Joelow30071's Avatar
    Paradise
    Quote Originally Posted by lilmanx01
    Do you have XP pro or home? Let's hope that your windows on your computer is "geuine" and not boot legged. If it is geuine, you in luck, since you probably have the windows cd that came with computer. Boot the computer from the cd, and there is a repair ulility on the CD, that will restore the master boot file. Without the master boot file, you computer will not load to with Windows XP logo part. It probabaly got deleted somehow. Try it, better than nothing. GOOD LUCK!!!
    Here is a article I found which goes in more in depth:
    Insert the Windows XP CD in your drive. Reboot the computer and press "del" (or whatever key combo gets you in) to enter the BIOS setup. Look for the boot order of your drives (usually under Advanced Settings). Change the order so that the CD drive is the first boot device. Save and exit.
    As the machine reboots this time it will find a bootable CD and prompt you to press any key to boot from the CD. Press a key. XP setup will now start to load - takes a little time before it requires input from you.
    Once setup is ready it will prompt you to press 'R' to enter the recovery console or 'Enter' to continue installing Windows. We don't want the Repair Console here so just press Enter. Setup will then prompt you to accept the EULA by pressing F8. Press F8.
    The next screen will show you the partition[s] available and will inform you that Windows is installed (usually on the C: drive). At this screen you will have an option to press 'R' to repair the current installation. Press 'R' and setup will then take over and do the necessary work.
    Paradise
    Default My load time
    My computer is pretty fast at loading up. Mainly because I have set to "quick boot" and my computer has the option to bypass the BIOS info most computers have to display prior loading Windows. It will load under a minute, with a "cold boot." But more often than not, I will put the computer in "stand by" mode, which saves time. Because when the computer is in stand by, all you have to do is press the power button on the computer, and will automatically your take you to your login screen or your desktop. Saves me about 40 secs, by not having to start the computer from a "cold start." The funny part is that I only have one stick 256 RAM on my computer with a ASUS motherboard and a INTEL cpu. Just imagaine how fast it would if I were to put in a 1 GIG of RAM running on dual channel. LOL. Anyways happy surfing.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Mine boots pretty quick. I remove alot of the start up processes and that help a bunch!
    Paradise
    I use startup inspector program, to remove any unnecessary programs from loading up, when windows start.
    Dunwoody/Sandy Springs
    my pc takes about 3-4 minutes. lol. too much pr0n i guess.
    Athens/ATL
    Now I'm actually curious to find out just how fast this goes.... all I know is my iMac is pretty fuckin fast.
    Norcross
    I Boot Like In 30 Secs...Less Maybe..
    decatur
    shut down and reboot. not just the boot.
