Results 1 to 4 of 4
Thread: 1g skipping time
    A clever title.
    Default 1g skipping time
    Sounds cooler than it really is...
    Got a friend with the early model 1g tsi AWD... The time keeps skipping and warping valves. A guy he knows said Mitsu had a recall on whatever it was that made 'em skip.
    Does anyone have a clue? I've searched and Goodle'd, but came up with nothing...
    '90 Nissan 240sx SE
    '97 Nissan 240sx SE - FS?
    Jay G. 1439/2000's Avatar
    Location, Location...
    There was no recall on whats making it skip time.
    When you do a timing belt job replace the tensioner, use an OEM Mitsu belt or Greddy/Toda/PE and ditch the balance shaft with OEM Mirage turbo parts or get a eliminator kit from a reputable DSM shop.
    www.vfaq.com
    www.4gperformance.net
    www.ebay.com
    Try those.
    A clever title.
    Thank you! He'll be glad to hear something about this problem!
    +some
    '90 Nissan 240sx SE
    Serious torque, In line 6
    Sounds like a tensioner issue, do a timing change and you should be ok. Also you may want to check the head out. Don't recommend doing a balance shaft elimination kit unless you plan on getting the bottom end balance. Use only OEM parts, change all tensioners, belts. Good time to replace the water pump.
