Results 1 to 40 of 43
Thread: Well there's faster car then the Veyron now...
    Woodstock
    Default Well there's faster car then the Veyron now...
    257.11 mph!
    1183 bhp...twin turbo v8
    Engine
    Type:
    Block and Heads (V-8)
    Displacement:
    387.2 cu.in.
    Bore x Stroke:
    4.125 x 3.620"
    Compression Ratio:
    8.975:1
    Horsepower:
    1183 bhp @ 6950 rpm
    Torque:
    1094 lb./ft. @ 6150 rpm
    Redline:
    7200 rpm
    Fuel Injection:
    Electronic Sequential Port
    Weight:
    422 lbs.
    Oil:
    SAE 5W/30 Fully Synthetic Racing
    Induction System:
    Sequential, multi-port fuel injection, Twin Turbo Chargers. Dual-Water to Air Intercoolers.
    Fuel:
    Premium Unleaded - 91 Pump Octane
    Warranty
    Basic Warranty:
    1 Year / Unlimited Miles
    Powertrain:
    Rust-Through:
    N/A
    Chassis & Body
    Layout:
    Mid-Engine/Rear Drive
    Body/Frame:
    Carbon Fiber/Composite/Steel Space Frame
    Brakes:
    Front: 14.0" Vented Slotted Discs/8-Piston Caliper.
    Rear: 14.0" Vented Slotted Discs/6-Piston Caliper.
    Wheels:
    Forged 3-Piece Alloy 19x9-1/2" Front, 20x13" Rear
    Tires:
    Michelin Pilot Sport PS2
    Front: 235 35 (YR)19.
    Rear: 335 30 (YR)20.
    Steering:
    Rack and Pinion, Assisted
    Turns, Lock to Lock:
    2.5
    Turning Circle:
    41.6 ft.
    Suspension:
    Front: Unequal Length Upper and Lower A-Arms, Coil Over Springs, Remote Reservoir-Adjustable Penske Coil-Over Shocks, Cab Controlled Air Lift, Anti-Roll Bar.
    Rear: Unequal Lengths Upper Rocker and Lower A-Arm, Adjustable Coil-Over Springs, Remote Reservoir-Adjustable Penske Coil-Over Shock, Anti-Roll Bar.
    The Ultimate Aero Dynamics
    Coefficient of Drag (Cd):
    0.357
    Frontal Area:
    19.0 sq. ft.
    Belly Pan:
    Complete flat belly pan with rear Venturi tunnels.
    General Data
    Dry Weight:
    2,750 lbs.
    Weight to Horsepower
    Ratio (lbs/hp):
    2.33 - New Production Record!
    Weight Distribution F/R:
    Front: 42%
    Rear: 58%
    Wheel Base:
    105.2"
    Length:
    176.2"
    Width:
    82.7"
    Height:
    43.0"
    Ground Clearance:
    4.0"
    Trunk Space:
    2.6 cu. ft.
    Accommodations
    Seating Capacity:
    2 Custom Recaro Seats
    Headroom:
    38.5"
    Seat Width:
    2 x 19"
    Leg Room:
    47.0"
    Seat Back Adjustment:
    25º
    Seat Travel:
    6.0"
    Drivetrain
    Gear
    Ratio
    RPM
    MPH
    1st
    3.00:1
    7200
    58.517
    2nd
    2.15:1
    7200
    81.651
    3rd
    1.5:1
    7200
    117.033
    4th
    1.1304:1
    7200
    155.294
    5th
    0.8667:1
    7200
    202.557
    6th
    0.6452:1
    7200
    272.102
    Final Drive Ratio: 3.4444:1
    Engine RPM @ 60 Top Gear: 1550
    Instrumentation
    Gauges:
    260-mph Speedometer, 8000-rpm Tachometer, Sequential Shift Lights, Horsepower Gauge, Oil Pressure, Water Temperature, Fuel Level, Volt
    Audio/Video:
    Navigation System, 10-Speaker Premium Audio/CD/DVD System, 7.5" Video/DVD Screen, Automatic Back-Up Camera
    Standard Equipment
    Includes:
    Air Conditioning, Power Windows, Power Mirrors, Tilt-Steering, Cab-Controlled Front Air Lift
    Record-Breaking Times
    0-60 mph:
    2.78 seconds
    1/4 Mile:
    9.90 seconds at 144 mph
    Skidpad:
    1.05 g
    0-100mph-0:
    11.66
    60mph-0 (braking):
    103 feet
    i'll still take the veyron though...
    Val RIP
    my only rule in life
    i'm a got dang wallaby!!
    2 bad it doesn't have Vtec....
    Woodstock
    http://www.shelbysupercars.com/photos.php
    btw:
    has no affilation with Shelby North American (carroll shelby)
    Val RIP
    Hampton, Ga
    whats the mpg
    Buslengths behind you
    that didnt take long
    MOST HATED
    Upstate SC/ATL
    Next stop: 300 mph.....
    2.0TRawr ironchef's Avatar
    You know whats sad? The car has about 200 more horsepower than the veyron, and it weighs close to 2000 lbs less, yet is only 4 mph faster. Thats where the engineering of the veyron really shines.
    Quote Originally Posted by ironchef
    X2
    also the veyron is faster from 0-60 by .2 seconds
    Norfolk, VA
    <---Click it.
    All bark, no bite.
    200 more HP, 2,000lbs less, 1,000,000x better looking than the Veyron.
    STILL HERE!! tron's Avatar
    loganville
    saw this coming! the veyron still reigns because of engineering its just better, thats why its such a big deal,
    -car and driver, 370z review
    Quote Originally Posted by iloveboost
    Looks are subjective, performance figures are fact. To have such a small disparity in performance vs such high power and weight differences is a testament to the Veyron's engineering, which should be highly respected. Personally, I think the veyron looks dope, and the interior is flat out gorgeous. Anyone can go and make what basically amounts to a kit car that puts out silly ass numbers like these, but too pull it off in such an amazing overall package like the veyron isn't an easy task.
    loganville
    x2
    All bark, no bite.
    That's why you have half a million dollars left over to customize it however you'd like.
    whatever both gets you laid
    Yeah its a 4 door
    4 MPH doesnt sound to much faster at all and it really isnt but when they are going at speeds over 200 MPH its hard to overcome all of the drag and air resistance so they engineered a better car more aerodynamicly really
    loganville
    Quote Originally Posted by Clegger
    C7 On_Her_Face's Avatar
    Duluth
    this>gayron
    ^yessir!
    Fake Suburban Environment
    Damn it looks like sex! And performance to back it up!
    1997 M3/4/5
    2004 X4 4.4i
    1987 325iS 24V 6speed
    Untrue, this is a huge feat both from an aerodynamics and a horsepower standpoint. 4mph is quite significant. Weight has nothing to do with top speed, just acceleration. The only things that matter are power and CoD. So, once again, this is an enormous feat especially considering the budget comparisons. And the 0-60, it's barely slower and the Veyron has AWD.
    - IA Mgmt
    Quote Originally Posted by fcman
    At 250MPH 4 mph is significant. Watch the veyron top speed run... the acceleration almost comes to a crawl at the top end!
    1997 M3/4/5
    2004 X4 4.4i
    All bark, no bite.
    Quote Originally Posted by DinanM3atl
    Let me know the next time you're driving 250mph and you need that extra 4mph to do what you set out to accomplish.
    Keep your 4mph and I'll keep the $500,000.00++.
    Exactly.
    - IA Mgmt
    Even getting 1 mph faster is impressive at such a high speed. You have to realize the amount of power it takes to overcome the drag at that speed. For example, it takes about 500 hp to overcome the drag at 185 mph...so if you've got a 510 hp car doing 185...you've only got 10 hp left over to propel the car any further.
    Anyway...kudos to SSC, but I think the car looks terrible. I'm also curious as to how composed the SSC feels at it's top speed. That is where the engineering of the Veyron shines. I want to do a top speed run in a Veyron before I die.
    I bet the SSC sounds wicked though.
    3 Cylinders of Fury
    You also need frontal area so that you can use the cD to find the total amount of drag.
    Quote Originally Posted by VteckTuna
    Yes, true. However, this is what wind tunnels are for (i've watched the one a Ga Tech run before, cool as shit)
    But you also have to remember that the Cd and Cl both matter here.
    - IA Mgmt
    everywhere & nowhere
    Canton, GA
    What about the Melling Hellcat?
    Engine: 6.0 litre v10
    Induction: 4 turbos
    Intake Cooling: 2 intercoolers
    Power: 1175 bhp
    Torque: 880 lb•ft
    Performance
    The predicted performance figures for the Melling Hellcat are:
    Top speed:275 mph (443 km/h)
    Power:1175hp
    It has also been given a 0-60 time of 2.6 seconds
    Also was this car tested to see if it could actually reach that 4mph faster?
    Canton, GA
    Barrett Parkway, GA
    ummm...you guys talk about it having 200 extra horsepower
    the veyron has a f'n w16...this is a v8...i think the engineering is better for this one than the veyron apparently. Gotta remember it weighs so much less because it has half the motor in it
    Veyron is more REFINED - you can't argue engineering b/c any car that can do that is very well engineered. The Veyron IS more refined as a complete vehicle.
    CA18FTMFL BITCH!!!! JBalla1036's Avatar
    Alpharetta
    ^^ Ya but it weighs almost as much as my moms QX56!!!!!
    Also, they weren't just going for "the fastest" car. They wanted to fastest, quickest, most luxurious
    Apparently, the Bugatti is very easy to live with despite having 1000 bhp. Like I said earlier...that is where the engineering of the Bugatti prevails.
    BOOB koukis14's Avatar
    Pennsyltucky
    They Veyron is a VW, no matter how fast is goes.
    Quote Originally Posted by koukis14
    So?
    Top speed is so 20 years ago
    Pennsyltucky
    So?
    I just don't like VWs. They are kinda peices of shit......atleast most of them.
    I don't care about top speed really...I care about construction and composition. I think 200 mph would be awesome...but 200 mph with the feeling that you're going 60 mph is what is really impressive to me.
    Oh well...I think they're excellent engineers.
    Pennsyltucky
    A mouth on the bottom of the steering column that blows you while driving would impress me. I always though that would be an interesting option.
