Thread: Need help on swap!
    Arrow Need help on swap!
    Ok im taking out the old and bringing the new... To start I have a 93 civic cx hatch and im going to put in a 99 civic EX SOHC VTEC engine in there. NOW what would I need to do to make this car run right... what to I need as far as wiring and such. Any help would be great.
    Jonesboro/Stockbridge
    Are you planning to keep the car obd1 or are you gonna make it obd2? Just wondering. Cause I heard you can convert the head to run on obd1 by changing the dizzy and something else..
    Quote Originally Posted by JDM onlyy
    Yea keep the OBD1 and just change the dizzy. Could I use the D15 non VTEC on the Y8 VTEC and run right? Or would I need a Z6 dizzy?
    ttt
    1.5T AnTi-PooN's Avatar
    L'villE
    obd2 and make sure you get that vtech solenoid or you wont get the vtech
    banned from heaven..
    fuck sohc, dohc is where its at.
    IA Guy
    Quote Originally Posted by Maniac
    Dont never say a SOHC cant do shit there ones out there that B series cant touch.
    Quote Originally Posted by Dyno
    Dont never say a SOCH cant do shit there ones out there that B series cant touch.
    its "sohc" not soch. lolol.
    IA Guy
    Fixed
    Quote Originally Posted by GSRteg®
    I think you're gonna need the z6 dizzy. I'm not quite sure cause I was wondering myself if a d15 nonVTEC dizzy worked on a z6 head...just bought me a z6 dizzy and got it over with. Thats what I think you should just do...
    Ok besides that what about the ECU buy a conversion harness to OBD2 to OBD1? Also use the OBD1 harness on the the engine and fuel injectors?
    Your Moms Moderattor
    pleasant hill
    With the Dizzy you need Z6 internals in a y8 Dizzy shell.
    Because the z6 dizzy does not line up with the bolt pattern on the y8.
    You can even use OBD1 wiring on the OBD2 motor, they are almost backwards compatible, there are a few sensors your are gonna have to get to just plug em up and let them dangle.
    Oh and I got a perfect y8 dizzy if you need one.
