Thread: brakes are mushy
    Murdy korilee13's Avatar
    El Paso,TX/ ATL @ Heart
    Default brakes are mushy
    ok heres the catch. they aren't mushy all the time, only if aplied slooooowlly. but any other time they are fine. master cylinder or what? sorry guys this is my first import. im used to old hot rods and trucks.
    btw its a 95 civic ex with a jdm d15 sohc vtec swap
    San antonio 210
    did u check the wheel cylinders ?
    if your suggesting the brakes are leaking at the wheels, i checked it, if not you gotta walk me through this.
    San antonio 210
    Quote Originally Posted by korilee13
    They just might be old and arnt working right any more..
    ight wheel cylinders...explain please.
    i had that problem.. it ended up being my master cylinder..
    Sounds like master cylinder to me
    - IA Mgmt
    Smyrna
    Same problem I had with my Jetta a while back. The brakes were mushy and progressively got worse until the master brake cylinder just died one day.
    OR air in the lines, bleed em, there easy.
    RISKY RISKYB's Avatar
    athens
    master cylinder or blown out wheel cylinders????
    more than likely the master cylinder
    A clever title.
    Just another idea... not sure at all... but could the actual brake lines be worn out/too stretchy? Hose dilating due to pedal pressure?
    '90 Nissan 240sx SE
    '97 Nissan 240sx SE - FS?
