Results 1 to 21 of 21
Thread: Why isnt my car starting?
    I wanna go fast!!!!! MrsDirtyOc™'s Avatar
    nevaneva land :D
    Default Why isnt my car starting?
    Ok so for the past few weeks my car has been hesitating to start so my bf tested it at his job(Autozone)......
    battery-fine
    starter-fine
    alternator-fine
    I go to leave work and it wont start.....doesnt make any noise.....
    We changed the spark plugs and still nothing.....
    The AC, lights, Pwr locks/windows still work when the key is on the on position.....
    Does anyone have any idea why this might be happening?
    "If ure not first, ure last"......Ricky Bobby
    custom_tuneup yuriyrusev's Avatar
    douglasville GA
    does it have spark?
    ......CUSTOMIZED.....
    Johns Creek
    You have to turn the key for it to start!
    j/k'ing....
    starter solanoid(sp?) or main relay edit: you said it made no noise, so i'm guessing it didn't turn over. if it turns overforget what I said
    nevaneva land :D
    Quote Originally Posted by yuriyrusev
    does it have spark?
    no
    Norfolk, VA
    ECU? FUSES?
    <---Click it.
    nevaneva land :D
    Quote Originally Posted by Whiteboy™
    ECU? FUSES?
    middle ga
    if it does turn over its most likely the main relay..if it does not turn over and makes no noise i would vote battery or something in the circuit from the battery to the starter
    Hwy 315
    If all your fuses are fine, then my vote is MainRelay.
    put the car in "on" position (dash lights = on)
    listen for your fuel pump to cut off, (*click*)
    if this doesn't happen, then take the relay out, and tap it on the ground. Occasionally they'll jam up internally.
    there is a way to test it out with a multi-meter and a battery, i forget the exact pin numbers though. (sorry)
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    Cobb/Cherokee County
    Quote Originally Posted by japan4racing
    x2
    nevaneva land :D
    no it doesnt turn over.......but when i turn the key im assuming its the fuel pump....it makes like a clicking noise.....
    we just changed the distributor rotor, cap, and wires i think thats what he said or something like that
    still nothing.....
    What is this relay i keep hearing about?
    Quote Originally Posted by MrsDirtyOc™
    still nothing.....
    if it doesnt turn over then you dont have to worry about the main relay
    Hampton, Ga
    its broke just give it to me
    Hampton, Ga
    but check your fuel filter
    West Staines
    silly girl...
    problem fixed
    Was there a massive lightning storm near your house with no thunder recently??? if so change the solanoid!
    oh yea...... AND GET THE F OUTTA TOWN! ALIENS OMGZORZ!!!
    HIV+ HalfBaked's Avatar
    Are you using the key?
    a track near you..
    What kind of car is it? Could be the main relay if it's an older honda, or the ignition switch itself. I had one that wouldn't start, and then 5 mins later it would. Finally figured it out, after I noticed it would start if you hold the key a certain way. The switch was all corroded inside.
    RISKY RISKYB's Avatar
    athens
    is the fuel pump kicking on
    West Staines
    silly girl...
    problem fixed
    lolz! i agree with this guy
    /thread
    Hampton, Ga
    what was the problem
