Results 1 to 31 of 31
Thread: As if the Veyron was not exclusive enough..
    IA's Chiropractor
    The Springs
    Default As if the Veyron was not exclusive enough..
    Bugatti Veyron Pur Sang
    Upset that everyone and 300 of their brethren have a Veyron? Step up to the Veyron Pur Sang, one of only five being built.
    What differentiates the Pur Sang is its aluminum body shell, which is made from an extremely pure alloy that Bugatti specified, as ordinary aluminum can polish irregularly. Underneath that skin is a carbon fiber monocoque which not only makes the entire car extremely light, but also incredibly safe - something worth considering when the 4,200-pound Veyron, which still weighs less than a modern Saturn Vue, has a top speed of 248 miles per hour.
    There is no word on pricing, but the usual disclaimer about asking applies.
    Bugatti is presenting a special edition of the EB 16.4 Veyron limited to five worldwide - the Pur Sang - at the Frankfurt International Auto Show. The limited edition will be numerically consigned to the ranks of overall volume designed for 300 cars. With the Bugatti EB 16.4 Veyron Pur Sang the company is continuing a tradition that produced icons like the T57 SC Atlantic and the numerous versions of the T41 Royale. Then as now Bugatti stands for a unique symbiosis of art, design and technology. Precisely this claim - manifested by company founder Ettore Bugatti and his son Jean - is reflected by the EB 16.4 Veyron Pur Sang, presented in a world premiere in Frankfurt. Reduced to pure design and technology, a car was created here that again was not the means to an end, but in fact had become a work of art in the sum of its parts. The EB 16.4 Veyron Pur Sang completely forgoes exterior paint.
    The idea for the EB 16.4 Veyron Pur Sang originated in the Bugatti factory in Molsheim. In what's referred to as the studio where the high-tech components of the Veyron are assembled with painstaking precision. "When some of our designers were looking at production and once again became aware of the technical beauty of the structure," says Achim Anscheidt, Head of Bugatti Design, "they came up with the idea of finishing the car in its pure material configuration. And that means without a coating of paint."
    The result is the EB 16.4 Veyron Pur Sang, a study in which carbon and aluminum blend into a unique two-tone color, although no paint is involved. "Interestingly," explains Anscheidt, "the pure materials used to underscore even more clearly the unified extremes of this car. Power combined with comfort, technical structure and organic bodies, light and dark. A closer look at the details reveals the techincal logic behind the stylish appearance. The innovatively designed monocoque carries all main structural components, including the W16 engine, the passenger compartment, the crumple zone and the suspension. It's precisely this foundation determined by function, made of carbon fiber coated with clear paint, that lies open in view at the heart of the Veyron. The use of aluminum linings is equally forceful. Through the bold and muscular coverings of the wheels as a perfectly designed wing they lend the car its stature and the unique body sculpture. Polished to a mirror finish, these perfectly curved shapes make the facinating surface reflections visible that characterize the Veyron."
    The balance of the visual impression is especially apparent when viewing the Bugatti from above. "These qualities," says Achim Anscheidt, "merge into a unique appearance - almost like a painting by Dutch artist Piet Mondrian." The outstanding representative of classical modern wanted to express the following in his art in the past century: "Beauty across the line and harmony by the balance of relationships between lines, colors and surfaces. But only in the clearest and most powerful way." This definition has also described a car for over six decades: the EB 16.4 Veyron Pur Sang. The two essential materials of the Pur Sang - thoroughbred in English - examined in detail:
    Carbon Body
    A car can never be light enough. This principal applies all the more so for the Bugatti Veyron, because it was designed for a sporty high performance. This is why the battle for each kilogram of weight has been one of the big constants in the development history of the Bugatti. Special attention was paid to materials: Only one material was used for each component, guaranteeing the best functionality at the lowest weight. Titanium, magnesium, aluminum and carbon fiber proved to be ideal.
    Thanks to carbon fiber construction techniques, the monocoque of the EB 16.4 Veyron Pur Sang is not just especially light, but - as it is known for motorsport - extremely safe. The monocoque is not just a rigid survival compartment, but can also ideally dissipate crash energy through elastic deformation. The main responsibility for this lies with the frames in which the carbon fiber monocoque is integrated - done in aluminum in the front and in combination of the carbon fiber and stainless steel at the back.
    Aluminum
    The parts made of aluminum show the meticulousness and will to perfection the designers of Bugatti pursued in their work. And this doesn't just apply to the body. The reason for this is that aluminum is normally a recycled product, resulting in a variety of impurities in the alloys. This has no effect on the characteristics of the material, but on its appearance. After polishing and anodizing the aluminum there can be different degrees of gloss. Not so on the inside of the Veyron, where aluminum is used with the material corresponding to the body shell: If you look closely, you can see that there are no differences in gloss here. Because a single, special alloy is used exclusively in the Veyron: AlMgSi 0.3 Vitral 42. No work is done with other alloys.
    All told, 1,888 kilogrammes of net weight stand in contrast to performance of 1,000 hp. This results in a power / weight ration of 1.88 kg/hp (4.15 lbs./hp) an excellent relationship that also positions the 400 km/h fast EB 16.4 Veyron Pur Sang beyond everything previously known.
    Thats Freaking incredible.
    ATL represent
    *bustanut*
    they really need to stop taking pictures of my cars..
    everywhere & nowhere
    Guess I will trade my V in for the upgrade.
    UH HOLY SHIT! Bugatti is my baby's daddy.
    Val for president!
    Facebook.com/TracyATL
    NW ATL
    ill take 2
    No
    OHYFUCKINGGOD.
    I just came.
    Twice.
    NW ATL
    Quote Originally Posted by RobbieDB
    OHYFUCKINGGOD.
    I just came.
    Twice.
    on my fucking veyrons? robbie, you cunt... wipe that off.
    Krispy Kreme
    its a nice car for a sunny day
    NIKOND80
    PG+K
    Norfolk, VA
    ill take 2
    fuck that, i will take five.
    <---Click it.
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    damn i want one..
    oh and BTW
    pur sang=pure blood..
    its french..
    The problem with this car was not the paint, it is the body. It's hideous.
    - IA Mgmt
    2.0TRawr ironchef's Avatar
    Quote Originally Posted by fcman
    Function over form in this case, though imo the exterior is pretty cool. And the interior is gorgeous.
    Newnan
    its great but the non paint thing is stupid as hell.
    learn to english
    blank
    nowhere
    sexy time
    I still love this.
    BodyGuy Civic_H2b's Avatar
    nices
    - Phu
    Sol_boosted k20siboii's Avatar
    sexiiness i want one bad
    MOST HATED
    Upstate SC/ATL
    I agree..I don't see the hype about Veyrons...
    Personally if I had that kinda money, there would numerous other cars that I
    would blow my money on before I would on a V. Seriously.
    Ex. Ferrari Enzo....
    When that car rides on the highway 4903229431810 people will die from being blinded and crashing into something. Nice, but stupid.
    Athens/Memphis
    That is ****ing amazing. Reps.
    UGA: Everybody is laughing at us this year.
    the old man NAIZBST's Avatar
    Quote Originally Posted by 81911SC
    x2
    ALL CAPS JITB's Avatar
    i "lol" at imagining what anyone would do with one of those in atlanta...
    id hit hwy.20 and just go straight...full throttle...
    Insaneness!!
    Resident Isuzu Owner Lusos's Avatar
    Barnesville, Georgia
    Quote Originally Posted by StuntallDay
    *cough*Spyker C8*cough*
    That Pur Sang does look like sex though...
    "Silkie Johnson is nominated [Player Hater of the Year], for calling in a bomb threat... To the Special Olympics"
    Be Vivid magneto198's Avatar
    ATL/lenox/Lville
    that thing is sick!
    flowery branch
    thats ****in badass!!!
    Quote Originally Posted by Lusos
    *cough**hack* Koenigsegg CCX*hack**cough*
    C7 On_Her_Face's Avatar
    Duluth
    ya ill take the ccx over anything, maybe not a zonda type f though with no paint and the cf showing
    DUH-KYOO-LUHHH
    its still not as sweet as the old eb110...
