Results 1 to 17 of 17
Thread: Broken Lug!!
    Murdy korilee13's Avatar
    El Paso,TX/ ATL @ Heart
    Default Broken Lug!!
    my driver side rear wheel tire has a broken lug, what all do i need to do to fix this, its broke off flush with the wheel, i'd like to fix all this on my own so a parts list or inctructions or really any kind of help would be appreciated. thanks
    Nissan by Nature LeX's Avatar
    here
    you just need to go to an auto parts store, buy a new one. You have to remove wheel, caliper, rotor, bang out old lug and put a new one in... when you put new one in make sure its in snug, use washers and then tighten and loosen a lug nut on it a few times to make sure its snug and safe before finally fitting everything back together
    72 Datsun 510 goon SR
    83 Datsun Maxima RB
    80 Toyota Cressida 4M
    Hwy 315
    depends on what type of vehicle
    for example...
    civics have a little slot in the hub that allows one to remove the broken stud without destroying the wheel bearing. Whereas integras do not have this. the bearing is destroyed in the process of removal.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    here
    Quote Originally Posted by CRXseven
    for example...
    -jonathan
    you have to destroy the wheel bearing? that's really screwed up heh
    83 Datsun Maxima RB
    It all depends on the car, if you want to do work yourself then spend the money on a repair manual.
    Quote Originally Posted by LeX
    no, when you pull a wheel bearing apart you aren't supposed to reuse it...there is no telling when it will go out after that point. May be within a few days or weeks or could possibly be months or longer if you're extremely lucky. Since you have it all apart might as well spend the $40-50+ on a new bearing instead of trying to press the old one in
    Quote Originally Posted by korilee13
    ...and yeah it helps if anyone actually knows what vehicle you're talking about
    95 civic ex is what it is, sorry bout that
    NO NO NO...When you take a wheel bearing apart, clean it an inspect it for wear, if its good just clean it an re-pack with bearing high temp grease an you be fine!
    Drifter/Kneedragger
    Buford, GA, USA
    if i'm not mistaken the wheel bearings in question are sealed/pressed type bearings.
    they are but when you take the hub off, then you see the ballbearings, an grease exposed, then you want to clean excess dirt, an grease an re gease then put back on
    ...and you've had complete success reusing wheel bearings in Honda's?
    Woodstock
    So heres a redneck trick for ya. Instead of taking apart the hub and rotor, grind off part of the new lug head and you can slip it in on the back side with a little elbow grease. It works fine, and dont give me crap about un safe. It works. Ive tried it and I Impacted the **** outta it to to test it.
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    Shine on! Nittanys1's Avatar
    Raleigh, NC
    damn this was posted almost a month ago...did you do it yourself or take it to a shop?
    Yes you can do that, But not on a civic's front hubs !
    Quote Originally Posted by Blitanicle99
    Krispy Kreme
    ^^ make sure you use an anti-seize.. but buy new ones!
    NIKOND80
    PG+K
    You can change a civic's front studs without taking the hub off. I do it all the time.
    Quote Originally Posted by Nittanys1
    i waited til i changed my drum shoes to change the stud.
    so just so the facts are straight... i took off the drum banged out the old one, put in the new one tightened it on with the nut. all is gravy. oh and just for everybodys info, as long as the bearings are all good and not odviously ****ed up you just clean off the dirt, repack with high temp grease and put your sh*t back together. riding good now, just need some wheels and tires, oh yea and a camber kit*ebay time*
