Results 1 to 27 of 27
Thread: b16b
    Right Side of the road
    South Side
    Default b16b
    i have stock b16b swap with full exhaust and intake, i want purchase an intake manifold, aebs or skunk2, is the stock manifold allright, is a 65mm throttle body good enough, im also wanting to put the skunk pro series pro 2 cams in it, are those cams the way to go
    South Side
    im also probably going to go nitrous , whats a fair shot for the internals
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    why buy an aftermarket manifold when you have a type r?
    South Side
    thats why i asked, i wouldnt have posted this thread if i already knew the answer. so the ctr manifold is just as good as the skunk and the aebs
    ECEFC.com
    Quote Originally Posted by jimbrown
    Damn homie, you dont have to get snappy!!!
    Anywayz
    I pretty sure those aftermarket manifolds are very copies the type r manifold with slight improvements.
    Pic of my 1st gen skunk2 manifold
    ^ buddy is right, the skunk 2 and aebs manifolds are pretty much replicas of the stock type R intake manifold, if you want a manifold with a bigger plenum and better intake velocity then go with the edelbrock IM's, throttle body size? keep the stock type R one as a bigger one wont really provide any noticeable gains. and skunk 2 pro 2 cams would be a good choice if your looking to spend the extra money for tuning and maybe even some higher compression pistons . . . btw im the guy that owns/drives the flat black coupe
    The Edelbrock Victor-X manifolds suck for N/A Hondas though, only get them if you're boosting. With nitrous, stick with a 50 wet shot; don't go too much bigger cause I'm not sure how strong B16B internals are but my B16 spun a bearing spraying a 75 dry shot (weak).
    \m/>_<\m/ dorin48's Avatar
    Canton
    B16's rod size vs. bearings and other small things yield it pretty strong (except in kevin's case) I would stick with a small shot because of your comp ration is a lil high.
    WHY NOT MR>KIDD
    you dont need to know
    i sprayed a 75 shot dry zex kit for 1 year with no problems and all i had was a 1st gen b16 , h,i e and msd basic ignition sci , and it was fine , so just buy cold plugs , retard timing 2 degrees only when ur spraying , and dont abuse it , and wet or dry will be fine , its ur call .
    DO NOT RUN NITROUS ON CTR PISTONS. Reps to the first person that tells me why
    Macon
    i heard the coating will melt off... or maybe not...
    Land Rover LR3 HSE
    Thats bullshit, I know a guy right now by the name of Heywood J' Blowme and he is running a mild set up with a 50 shot right now ! LOL no but really I like to know why you say no to Nitrous on ctr pistons?
    ringlands weak? give me my reps kidd!!
    hustler ksniperfox's Avatar
    lawrenceville
    b16b pistons split the combustion flame into 2. not as volumetrically efficient, but not good for nitrous. puts a lot of stress on the piston.
    "The pistons are a high-pressure die cast construction. This is the best way to make a cast piston. Since they are cast, they are not the best choice for a nitrous oxide-burning engine but they are excellent in all-motor applications."
    they are too high of a comprrrrrrrrrrrrrrression lol
    JDM TYTE AnthonyF's Avatar
    b/c they like to go BOOM
    The Carbon Fibered R6
    Reps to KsniperFox and Scotty
    Jonesboro/Stockbridge
    weak ringlands right?
    In a mansion
    So you can run a small turbo setup on these motors, but no nitrous? I find that hard to believe, but then again i am no certified mechanic.
    the piston design is what makes it hard to boost. the CTR pistons have a HIGH DOME whihc creates a nice hotspot.
    Adding boost or nitrous will just create an environment that is not safe. its also 10.8:1 compression with a cast piston with a high dome.
    this kid sure he has a b16b if he is asking these questions?
    Digital Box Tuning
    In a mansion
    Quote Originally Posted by josh green
    Actually we just looked at his block i think accidently wrote the wrong block code. It's crazy i didn't think honda would make mistakes like that.. Get the fuck out of here.
    lawrenceville
    b16b pistons have a pent style top. limits the longevity of the motor but makes more power NA. nitrous/boost would severly reduce the life of the motor.
    thanks for the reps, i returned some
    Quote Originally Posted by sleepys4
    To have a b16b and know you have one, I would not expect someone to be asking such uneducated questions. But I forget yall are not "certified mechanics."
    Digital Box Tuning
