Results 1 to 13 of 13
Thread: Polishing SIs
    1st project
    Hoschton
    Default Polishing SIs
    Anybody know a site or have any tips on polishing SIs.
    Senior Member DerrickT's Avatar
    Athens
    www.honda-tech.com
    Search Feature.
    Hwy 315
    i just finished polishing out my set of "sawblades"
    To achieve a mirror finish you will need:
    0) spray bottle full of water
    1) 220 grit
    2) 400 grit
    3) 1000 grit
    4) 2000 grit
    5) Mothers Billet polish (the 15$ can at autozone)
    6) lots of time and patience
    I used a metal brush attachment for my drill to get the paint off three of the wheels. By the time i got to the fourth wheel i was sick and tired of that, and decided to use paint stripper. (bad idea) It took the paint right off in a matter of minutes, but for whatever reason, that wheel that i used it on has a slight haze and isn't a mirror like the others.
    Take time to clean the wheel in between stages and make sure you keep a constant stream of clean water on whatever you're sanding, you don't want all the debris the paper takes off to be constantly rubbing on the metal.
    Take your time bro, it's a lot of work. It's not hard, just tedious and repetative.
    www.honda-tech.com/zerosearch
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    ATH GA. SRCRX's Avatar
    On the drum set!!
    Quote Originally Posted by TheTurtle
    www.honda-tech.com
    Search Feature.
    1st project
    Hoschton
    Alrighty, So the grits you put on, that means that I should sand it down in that order? Oh and what is that link for, I don't know where to go on that website.
    1st project
    Hoschton
    A metal brush? What kind of metal brush should I buy, is there a name brand or something I should look for. I'm still kind of new to polishing rims, could you be a little bit more detailed.
    1st project
    Hoschton
    No more responces.............
    Fayetteville/PTC/Carrollton
    dude go to honda-tech.com like they said and search
    there is also about 20 threads on IA if you just search..its alot easier than asking people.
    Hwy 315
    - Walk into Home Depot and ask those guys to explain what a metal brush attachment is...
    - Yes you do them in that order, that's what the numbers are there for
    - You click on the link we gave you, type in "polishing wheels", click "ARCHIVE" over on the right side, and click SEARCH on the form.
    *sigh*
    -jonathan
    [/URL]
    Quote Originally Posted by CRXseven
    *sigh*
    -jonathan
    exactly, thats what the search feature is there for. probably every question aboyt anything honda will be on h-t
    Hwy 315
    Quote Originally Posted by ryanh300
    ...you wouldn't believe some of the stuff I've found on there...
    i think that anything about ANYTHING can be found on hondatech
    -jonathan
    [/URL]
    -jonathan
    I agree
