Results 1 to 5 of 5
Thread: wut ecu to use for b20 swap
    werd.........
    atl
    Default wut ecu to use for b20 swap
    wut ecu do i use on a stock b20 motor ?
    in my da as of right now i have a p72 obd1
    Many people use LS ECU.
    werd.........
    atl
    u think thats the best way to go
    is it a b20 or b20 vtec? the best is a socketed/chipped p28 with tuning, but if you're trying to go with a drop in and go replacement then the stock b20 ecu is the best. if it's b20 vtec then there isn't a best drop in and go ecu. if you're trying to do that then use the ecu from whichever vtec head you're using (gsr head use p72, b16 head use p30) and then get an adj fpr as a band aid to try and raise lower fuel pressure for the fueling needs.
    hope that helps.
    werd.........
    atl
    helps out alot def coming to u for tunning when done if still have cash left over man .....
    i dont kno witch one to do tho i have gsr head good condition but would it be easier to just swap it out or just putt b20 block
    thanx again
