Thread: When shifting gears...
    w00t Black Mamba's Avatar
    Nowhere Near You
    Default When shifting gears...
    I have an eg with LS swap.
    The shift is very short, but the clutch is VERY LONG, meaning where the gears engage, it engages at the ALMOST at the end of the clutch.
    I mean, you will barely EVER stall out even with newbie driving it.
    I was teaching my gf how to drive stick with the car, and she never stalled out. That's how easy it is to drive. ANYHOW.
    Does anyone know what the problem is? will it be the shift linkage? or the clutch?
    Any help?
    NWS FTW
    Wasting Fossil Fuels n2daizo123's Avatar
    Quote Originally Posted by AllStock
    Any help?
    you can adjust the clutch pedal to where it engages the clutch more towards the floor. click Not your car but the same concept.
    NRA Member
    GCO Member
    Newnan GA / Clinton SC
    yeah i think u might be need to adjust the clutch pedal or the clutch (shift) link
    Low-n-Slow iEvo's Avatar
    Gnett
    either that or the clutch is worn.....to see if its good put ur car in 5th and try to drive off like urin 1st. if it stalls then ur clutch is good, if not then its bad
    t(-.-t)
    shit... once your done taking off your clutch will be shot..
    So either way.. get a new clutch. never go back to OEM. upgrade. when something stock goes out, replace it will something 2x better if not more! trust me on that shit... never go OEM.
    Quote Originally Posted by BlackIX
    t(-.-t)
    Unless you are as broke as i am.
    Go Dawgs
    SouthSide
    I go oem on certain stuff, but stuff like clutches...hell no
    Tuned by Lil Ray Ray's
    Quote Originally Posted by Mr.MuayThai
    If you get a new clutch its still a good idea to adjust the pedal to let out when you want it to, especially if you get one with more clamp load.
    NRA Member
    GCO Member
    Nowhere Near You
    thanks for the info
    NWS FTW
