Excalibur, Omega's flagship brand, is an advanced, full-featured vehicle security system. The ATV-1000 provides an arsenal of programmable features, so you can truly customize your system for the convenience and security that best meet your needs.
Model ATV-1000
Standard Features:
• 2 high-frequency 433MHz code-jumping transmitters
• AU-84TA dual-zone shock sensor
• Starter interrupt relay and socket
• Flashing parking lights
• Dome light supervision relay built-in
• "Smart Trigger" automatic door trigger detection circuit
• Negative door trigger input
• Positive door trigger input
• Negative hood/trunk trigger input
• Plug-in auxiliary sensor port
• Negative doorlock outputs with harness included
• Dual negative unlock outputs for optional driver's door priority unlocking
• Psyren(TM) multi-tone electronic siren with programmable confirmation chirps
• Negative trunk release output
• Status LED, valet switch, programming data port in easy-to-mount holder
• Negative 3rd channel output
• Backup battery circuit for optional 9-volt battery
• Remote panic feature
• Patented ATV transmitter-tampering protection
• Patented Unauthorized Transmitter Alert
• NEW "Safety Disarm" operation
• NEW easier-to-use silent arming / disarming operation
Programmable Features:
Click on a feature to see an explanation.
• Selectable coded Override
• Automatic rearming
• Ignition-activated anti-carjacking
• Automatic starter interrupt
• Door activated anti-carjacking
• Last door arming
• Doors lock with last door arming
• Current sensing
• Doors lock upon ignition on
• First door unlock upon ignition off
• Second door unlock upon ignition off
• Open door bypass of ignition lock / unlock operations
• Parking and dome lights illuminate for 30 seconds upon disarming
• Doors lock with automatic rearming
• Trunk release also disarms system
• .8 or 3 second doorlock output
• Single or double pulse unlock output
• 3 or 45 second arming delay
• Confirmation chirps on or off
• Confirmation chirps in valet mode
• 30 or 60 second triggered alarm duration
• Steady output for siren or pulsed output for horn
• Loud or quiet confirmation chirps
• Total closure door lock output
• Transmitter-activated anti-carjacking
• Open door warning upon arming
this is brand new in the box never installed... can even help with installationb on any car... all ill do is tell you the wires to hook up though.
$100 or trade for good headunit.
