Results 1 to 10 of 10
Thread: FS: Si cluster, PasswordJDM, pod, obd harness, HKS, Cams, Intake
    Cambodia
    Default FS: Si cluster, PasswordJDM, pod, obd harness, HKS, Cams, Intake
    1) Civic Si Cluster
    - Mileage is 127,907. All you swapped EK's looking to look more like an SI... this is a MUST. It's got a Carbon Fiber face from I don't know where, lights up JDM AMBER and is in awesome condition. Don't let the mileage make you weary of its ability to go to 9500 rpm! $200
    2) HKS SSQV on an EK cold pipe.
    - Pipe has no leaks and the bov still sounds very much fast and furious!! $175
    3) OBD2B to OBD1 Conversion Harness
    - All pins are still secure and tight. $90
    4) PasswordJDM EK Cooling Plate
    - It's bronze in color with a VIN cutout. This little piece will cover up the holes on your radiator support and reroute the airflow to your radiator for optimum cooling! Plus it's JDM. $60
    5) DC Sports Intake
    - Direct Air Charge! It's a short ram, but its awesome for anyone looking to make a bit more power and a bit more noise. Came off an Integra (DC) $60
    6) B16 Camshafts
    - stock, in good condition. PERFECT for you B16 guys that lost your B16 cams. $50
    7) Triple Gauge Pod
    - This interior greyish looking piece will replace your entire A pillar in any EK! This is a must for you multi-gaugers. $25
    8) Integra Upper Driver Side Mount
    - a PERFECT stock replacement for those folks that needs a stock replacement. It's perfectly unbroken. $25
    Attached Thumbnails Attached Thumbnails -si_cluster-jpg   -hks_civicek-jpg   -obd_conversion-jpg   -cooling_plate-jpg
