Results 1 to 35 of 35
Thread: Run in Brandons Del Sol yesterday.
    Default Run in Brandons Del Sol yesterday.
    Decently fast Del Sol would have been faster if Vtec engaged earlier and he was running slicks. Has a JDM type R engine. Is white with red rims. Probably seen it yesterday as he ran like 213123789 times.....and he said he wanted to go easy on it. Cheers.
    1/4 time?
    Norfolk, VA
    times?
    <---Click it.
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    wrong section
    decent runs, though. I think.
    Yeah Low 15s most of the day. lowest being 15.1 I believe.
    With the huge wing in the back?
    That was pretty fast times.
    he driveth furiously Jehu's Avatar
    North Atlanta area
    Nice run...what's the weight of a del sol? Those gears seem pretty long. What tranny?
    Formerly Daily Interlude
    livin again collins's Avatar
    chillin in the sloooo gtoooo
    15.1? hell my integra did that with a b20 and bolt on's! and it was slow as sh!t!!!
    Cruzan Boy Siverprobegt's Avatar
    ga/VI BREED
    Samething i was thinking,it sounded lazy,and the gears seems long as hell....Don't a stock type r runs faster time stock???.
    Quote Originally Posted by Daily Interlude
    92 mx3
    Newnan
    i run a low 15 in my basically stock SI..
    seems like the passenger and a camera was adding some weight..
    lose weight cameraman!
    learn to english
    Athens/ATL
    sluggish as shit mayne... on a type R he should be running WAY quicker.
    And everyone asking, a stock DOHC VTEC model del Sol (with a b16a2, a/c, cruise, p/s, etc) weighs in at 2,491lbs without driver, and runs the quarter in 15.5 stock.
    Modded Type R (which I'm assuming he's running basic I/H/E bolt ons...) should be running at least mid 14s.... my tuned/slightly modded GSR sol was running pretty consistent 13.7-13.9 quarters on fresh street tires.... The trans is geared way long.. almost sounds like an LS trans? Either that or your boy's a bad driver... and I mean bad as in bad.. not bad as in good...
    15.1? i would kill myself if i ran that with a type r engine, hell i would kill myself if i ran that with my ls.
    Jay G. 1439/2000's Avatar
    Location, Location...
    Long gears is caused by no power to make them seem shorter.
    15.1 is what I ran with a GS-R gearbox and no LSD spinning 3rd gear. I bet he wasn't pulling off 1.9 second 60' foot times on 17" wheels and street tires with shitty suspension though
    I'm sure it was really hot too so cars weren't running their best plus how many idiots out there on street tires were playing in the water box screwing up the track
    North Atlanta area
    Well, a lot of you are bench racing quoting numbers. All that run their FWD cars on street tires know that Commerce is not the best track for us. So cut him a bit of slack.
    I've raced a type R or two in my H22 88 Lude and they've run 15.2-15.3 modded. So maybe his wasn't the best run but I'll cut him a little slack. My lude "should have" run mid 14's but all I could get out of her was a 14.8 @ 93-94mph running a 2.3 60'. And I've never seen a FWD drop below 2.0 60' on street tires...I seldom see them on drag radials. So kudos to speedminded for being able to drive!
    To really see what the car's capable of, post up his trap speed and even his 60' time (60' time will tell a lot about the drivers abilities while the trap speed will show the cars abilities).
    Though I will say that I ran a 15.1 at last years Tunerfest in my lude but I had just put in an untuned P28. I dynoed it on site at the show and it hit 144hp and 145 torque! lol But who knows how accurate the dyno really was. A tuned H23 vtec had just dyno'd at 220hp and it only hit 180 at that dyno...
    Quote Originally Posted by AirBrcak
    Wing was on there when they bought the car....and I dont think it looks too bad.
    Its a JDM type R engine, but its using a gsr tranny.
    Quote Originally Posted by EBP_EM1
    Dude..I only weigh 150.
    Quote Originally Posted by xPhantomSolx
    Yeah the tranny is a gsr tranny. they have ordered the type r tranny though.
    Quote Originally Posted by blown_ss
    It seems like Vtec is not engaging when its supposed to. I just
    He was running gsr tranny as well with no lsd. Was spining in 1st, 2nd, and 3rd as yall can see. He was only running 16 in wheels with bf goodrich g force tas. Suspension is a full eibach coilover suspension.
    ah, yep sounds about right then, I bet 2nd gear it drops out of VTEC doesn't it? It's too high, using a VAFC i lowered my engagement 200 rpms so it would stay in, does it honestly help...not sure That car is 14's all day with an ITR tranny...headwork, fuel, LSD, & slicks it should run 13's.
    I ran a stock ITR and a DC2 with a H22 all night...the ITR was getting a 14.9 and the H22 DC2 14.1 just about every single run. My R/T was quick enough that i could beat the ITR across the finish by 1/2 a car length but he was still trapping 2/10th's a second and couple mph faster. I couldn't touch the H22 DC2 after 2nd gear, nearing the top end of 2nd i was always 1/2 a car length ahead but it was almost like he was spraying once he got into the top end and shifted to 3rd....torquey lil monsters. Plus i have practically no back pressure on my exhaust and my cams are tuned for mid range....top end is just about non-existant.
    As for the Del Sol with a stockish b18c1 running mid 13's...if it was on street tires with a GS-R transmission then it didn't happen at Commerce or Silver dollar unless it's stripped down to nothing: no glass and holes drilled everywhere. If it's a near stock body with a near stock engine then it's either spraying or has a crazy fuel mixture. Now if it was an 1/8 mile track with a 1/4 mile ETA might as well cut off the bottom half of the time slip Let me know what it was, i'd like to hear about it.
    Athens/ATL
    You're right.. it didn't happen at Commerce or Silver Dollar...Me being in Savannah, the closest quarter mile strip is Carolina Dragway, which is where I ran a 13.7 after I honestly thought I had jumped the light. The interior was out for the most part, and the ecu tune was quite aggressive... how aggressive I don't really know because my friend Kevin out of Birmingham, AL tuned it and sent me the ECU. The timeslips are back in Savannah at my apartment, but I'll be more than happy to post them for you guys to see when I get back to Savvy in a few days.
    PS - Carolina Dragway is totally worth the drive. Mostly grudge racing/street cars, so you don't get the crazy bumps and crappy prep of Commerce.
    North Atlanta area
    After posting my times with the H22 88 Prelude, I had to explain to everyone on PreludePower.com why my times seemed a bit slower than expected. Running at Commerce is not good to compare numbers from other tracks. It's typically 2-3 tenths slower from what I've found...and that's comparing to Steele in Al. Commerce to Silver dollar, Silver Dollar has about a 1-2 tenths better times.
    The best you can really do is compare numbers from the same track. At least you're closer to comparing apples to apples.
    Athens/ATL
    personally I'm terrified of commerce.. All the bumps at the end make me nervous and I usually end up braking before the end of the quarter. But I'd love to take a look at that sol... Ive got a few tricks up my sleeve that could get it running a lot quicker...
    Ok guys learned a few things. Ok hes not even running the gsr tranny, just an ls tranny, unlike they had thought before. 2nd I guess yall dont know but this is a bone stock jdm type r motor, meaning no mods. Thirdly there is something wrong with vtec engaging too later + the clutch is fried. New tranny going in over the nect two days though. Cheers everybody, and Brandon says thanks for the comments and hell prob get an acount on here again.
    Athens/ATL
    BOOM CALLED IT ON THE LS TRANS! MUAHAHAHAHAHAHAHAHA!!!!!
    *takes a bow*
    But the clutch shouldn't have anything to do with VTEC engaging late... that's either an ECU issue or, worse, an oil delivery problem to the head... If I were Brandon, which I'm not, but if I were, I would get that VTEC problem solved PRONTO... IE before romping on it again. If it's an oil delivery problem, he's begging for a blow. And not the warm moist kind either.
    *takes a bow*
    Yeah thats getting looked at tomorrow more than likely, before they drop the other tranny in.
    Athens/ATL
    who is "they"?
    who is "they"?
    Friends and his father.
    Athens/ATL
    hmmm... tomorrow huh? In Gainesvegas? I could possibly be tempted to run up for the afternoon and lend a hand/some insight if they need it.
    Well hopefully it is tomorrow, but might be wednesday, I know he still has one bolt left to get off the other tranny on his parts car before the tranny can come out, so they will install it either tomorrow or wed. more than likely. Ill pm you.
    GoonSquadsNinja JDMjoe's Avatar
    i85north
    Good luck w/ the tranny swap
    The black supercharge d16 Del Sol ran a 15.89
    North Atlanta area
    I'm telling you guys...Commerce isn't pretty to FWD rides! lol
