Originally Posted by
allmotoronly
man I have looked at these before and In my opinion I would stay away from these. Its cheap stuff. I would just go with real oem honda parts. You can get pretty much all the gaskets that are included in this kit from honda for less than $200 (including head gasket). Get a set of Type R pistons and rings for about $270, and a ACL bearing kit for about $65. All in all, you will have to spend a little more, but you will get real honda parts and the highest quality bearings. I also suggest a new Oil pump while you are at it. You can get a type R oil pump for around $100. When is the last time you changed the timing belt, water pump, and idler pulley? you might as well to that while you are at it. good luck with it man. My GSR has 90k miles, and I am considering doing a light rebuild at 100k (new bearings, pistons/rings, etc).
