Thread: How can i check the oil trasmissions 4 a 99 323i
    Certified Gearhead EL_DISTROYEL's Avatar
    Default How can i check the oil trasmissions 4 a 99 323i
    i have a 1999 323i i need to check the oil transmission how can i check?
    Quote Originally Posted by EL_DISTROYEL
    Don't think you can and shouldn't need to. How many miles on the car? Might just want to drain it and replace it.
    about 133,000 miles because everytime i drive the car it will drive good and then a code pot up on the dash bottom part is round with a line in the middle everytime that comes up the car drives slow and u have turn off the car for a min turnet back on and it stops they told me it was the transmision that need oil i dont know
    no accord
    alpharetta
    is the car automatic.
    RESIZE PIC PLEASE
    yeah
    bavarian motorsports FTW!
    where ever theres food
    i hate to break it to ya but check it before you decide to change it just because if the tranny started to go and you change the fluid it will do nothing but expedite the process. so check it and if its not still a clearish redish color i wouldnt suggest changing. but if its auto you should have dipstic i think a yellow handle
    "The M3 engine does not develop it's power ... it is simply present in an overwhelming quantity at any time. "
    AutoZeitung 1992
    no accord
    alpharetta
    typically on the 3 series you should change the tranny at 100K if its an automatic. the oil bmw uses in the auto tranny they claim you shouldnt ever have to change. Although you might want to try that first get on e46fanatics and see what ppl are using. i dont have a auto so idk. but my 2000 328 has 143K on it and it runs like a dream and i put redline atf D4 in the tranny (shifts smoother)
    RESIZE PIC PLEASE
    Fake Suburban Environment
    Quote Originally Posted by sina518
    At 100K? You are 60-70K overdue... And I would never change it at 100K... definitely not on an e46 auto... Quality went WAY down on the 3 series Auto compared to the e30 and e36.
    And your car is going into the "limp home" mode if it is going slow and won't go over a certain MPH. Something is majorly wrong and it is probably NOT low trans fluid.
    1997 M3/4/5
    2004 X4 4.4i
    1987 325iS 24V 6speed
