Thread: WTB ANY SINGLE CAM SWAP
    come get some superman's Avatar
    Dream Land
    Default WTB ANY SINGLE CAM SWAP
    LOOKING FOR ANY SINGLE CAM SWAPS COMPLETE GIVE ME A CALL SEND ME PICS SEND ME PMS 404-819-2838
    Resident Pimp jackdaripper's Avatar
    This engine has about 150 miles on it as you can tell how clean the pistons and cylinder walls are. I pulled the head only to take pictures of the pistons so yoy would know what your buying. Strongest sohc car I drivin personaly. Had rough idle due to high compression. Should be tuned, I will reinstall head upon someone buying engine so you can see personally the internals. Only reason I pulled engine is I got a great deal on a b series swap that I couldnt pass on. I will split the engine and the head and the engine will not come with injectors or throttle body and a couple of sensors other then that its complete. I also have a 8lb flywheel and a lightweight crank pulley for the engine. Engine has new acl bearings new rings reconditioned rods with arp rod bolts I will take 600 for everything or 400 for short block 80 for flywheel 120 for complete head and 35 for pulley
    "Owning a 9 second import is like coming out of the closet. At first you surprise everyone, but in the end you're still gay!"
    Dream Land
    Dream Land
    ttt
    Dream Land
    pmed
    Dream Land
    up
    Jonesboro/Stockbridge
    I got a d15b7 that needs new rings. Long block. 200 bucks. Will have pictures later. Also got a dual cam ZC if you wanna use that...its still a D series...
