Results 1 to 14 of 14
Thread: Exedy flywheel or ACT street lite flywheel?
    YEAH! bRiAnMcIvIcS's Avatar
    Default Exedy flywheel or ACT street lite flywheel?
    Which flywheel would you guys prefer on a 99-00 honda civic si, an exedy lightweight flywheel or ACT streetlite flywheel?
    Norfolk, VA
    Fidanza
    <---Click it.
    I'm using ACT PROLITE
    Banned tippatone's Avatar
    College Park
    X2
    Quote Originally Posted by xbn83
    Quote Originally Posted by bRiAnMcIvIcS
    The Exedy race is one-piece chromoly and the ACT isn't right?
    Can't link a search script like that... 54,333 results found
    ACT PROLITE and STREETLITE are all 1 piece design. I believe ACT does not make any multi-piece.
    http://www.carolinaclutch.com/SQLCar...rge/100168.jpg
    thanks dudes.
    Certified Gearhead bernard's Avatar
    J-ville FL. FR. O'side Ca.
    I used to have the act pro lite, its good to go. And its one piece. Now i have a Fidanza 2 piece. Loving it. And its rebuildable. There both pretty good to me.
    (sī'kə-pāth') ZedEx's Avatar
    Wilmington, NC
    Street-Lite is kind of heavy... I have one, and it's heavier than my stock Type-R flywheel.
    A Type-R and a Type-SH.
    How much does the stock b16a2 flywheel weigh? So if i get the exedy flywheel(10lbs) or the act pro-lite(9lbs), how different will it drive? I heard you can lose some torque also, is that true?
    Macon
    go with the exedy. It is chromoly steel, not aluminum. It is stronger and a one piece desigh, so reliability will not be a concern. The one pound difference between the act and exedy will not be noticeable. As far as reliability goes, I have had three aluminum flywheels and one exedy chromoly. The exedy lasted longer than both fidanza's and the other aluminum one I had (cant remember brand...)
    Land Rover LR3 HSE
    Thanks dude. I'm gonna go with the Exedy.
