Thread: Tune ? For D Series
    FUK IT! bowdown201's Avatar
    Next Door
    Default Tune ? For D Series
    I plan on turboin my d series motor in less than a month and i was told since the full turbo kit i am gettin was off the same motor as mine stock and mines stock that i wouldnt have to get it re-tuned. is this true?
    Augusta Ga
    i would .... jus to be sure it is tuned ... he might have jus said he had it tuned an never did ..... so be safe and get it tuned .
    93 sol Si
    95 sol S
    95 sol Si
    Don Mon SiRed94's Avatar
    Morrow 30260
    it depends on what device he used to tune his setup, and what he is giving you with the setup... if you are getting something mechanical such as fmu... then no, most likely you won't have to "tune" it, but if you are getting something electrical like VAFC with 450's then yes, you will most likely have to tune it...
    02 WRX patrick4588's Avatar
    warner robins
    i would get it tuned just to be safe.
    a tuned map on one car is just a basemap on another even if the setups are identical. you never know when the flow of air or fuel may be different after you swap everything over.
    get it tuned to be safe and sure.
    I am Montage
    Augusta, GA
    ^^^ listen to the man, he knows what hes talking about when it involves tuning
    Atl
    yes he does
    I can vouch for him too
    K-What?!?!
