Results 1 to 22 of 22
Thread: need help please on my turbo setup..
    eat.. sleep.. boost. teamjdm4dr's Avatar
    snellville
    Question need help please on my turbo setup..
    i now have my car back and its still having problems and i dont know what to do with it .. i have everything on it but its just not starting up.. i was able to drive it home but now its not doing anything.. the motor is a D-15 Z1 with a V-tec head.. if anyone knows about boosted cars or how i can get it running or even a local shop around gwinnett let me know please.... thanks a lot.. -matt
    sold s13 hatch CA18det .. wound up it had a blown head gasket before i bought it and didnt tell me
    SOLD!!!!!
    Augusta Ga
    junk the z1 bullcrap get a z6 ...... then boost that .... thats the crappiest vtec motor u can put in any car ........ so do yourself a favor spend like 300 bux drop it in yourself an boost wutever u buy ....... the z1 sux in every aspect of the motor itself ..
    93 sol Si
    95 sol S
    95 sol Si
    02 WRX patrick4588's Avatar
    warner robins
    so what exactly is wrong with it? have you changed the dizzy cap and rotor? spark plugs and wires?
    Rock the 40oz GTScoob's Avatar
    GA Tech
    Fuel, air, spark. An engine needs all three in order to start. You're not getting one of those so check it all out.
    02 WRX Sport Wagon
    Alabama
    We really need to know exactly what happens(or doesn't happen) when you try to crank it in order to give you any type of advice.
    snellville
    im sure the fuel is right now.. but when i try to crank it its not turning all the way over. i know the timing is probably way off now.. so when i try to crank it. the fuel pump comes on and the starter turns on and everything but when it cranks it shakes bad and it starts poping like its running too lean and it stalls out.. well its hard to explain on here... but its been in the shop for awhile and im just getting frustrated on it and i was right about to just trade it for something else.. so i guess just let me know what u think it is.
    Quote Originally Posted by Autoworks
    SOLD!!!!!
    Grayson.
    matt, go big, swap that motor for at least a d16z6, or better, buy my car. 15000 and its yours.
    95 ej1--------536whp at 20psi on race gas!
    96 db7-------DD.
    95 eg1-------Sold
    94 dc2-------totalled
    94 dsm------donated to charity!!!
    WE RUN THEM BABY TURBOS AND BIG MANIFOLDS!!!!
    have you ever driven it yet? i thought i would've heard from you by now regarding tuning it.
    Don Mon SiRed94's Avatar
    Morrow 30260
    well, first of all, are you throwing any check engine lights? also make sure you are getting spark and fuel on all cylinders... its hard to diagnose without being there, but if you have fairly new ignition parts (cap, rotor etc) and aren't getting any check engine lights, i would check the timing and make sure the belt didn't jump any teeth... g/l
    drives a trycicle
    newnan
    get some some new spark plus and please get ngk then we'll start talking
    Boost Junky Jordanmd88's Avatar
    sounds like the timing belt slipped..
    snellville
    thats wat i was gonna do in the first place but i just got the motor from sherman that one day and he supposly said that it had internals too.. but idk.. yeah i would buy the coupe if i can get about 14500 from ya.lol but yeah ill give ya a call lata.. -matt
    Quote Originally Posted by soplocar
    SOLD!!!!!
    snellville
    i drove it back from the shop i had it at.. but it was still running real rich and it couldnt go past around 3000 rpm. i was told that some wiring for vtec wasnt hooked up so it wounldnt go past it.. but idk what it is now.. but ill give you a call when i have it on the road and ill go tune it...
    SOLD!!!!!
    snellville
    i dont know if im getting check engine lights cuz my friend took it out cuz i was driving it for a few days without an O2 senser and it was buggin out.. but i have a new cap and all of that i think i might have to get a rotor.. but im pretty sure mine is still good.. ill check the belt again.. thats might be what it is anyways.lol ill let ya know what goes on with it.. thanks -matt
    Quote Originally Posted by SiRed94
    SOLD!!!!!
    snellville
    thats what i had in it before and they flooded out from the injectors.. but yeah theres new ones in it.
    Quote Originally Posted by HOMEMADE240S
    SOLD!!!!!
    Grayson.
    cmon matt, ill let you make payments on it.
    96 db7-------DD.
    95 eg1-------Sold
    snellville
    that will take years for me.lol you know that look at my car now.lmao
    SOLD!!!!!
    Certified Gearhead n1accord's Avatar
    Southside
    how long has that fuel been sitting in there? a lot of times what can happen is that if a vehicle sits for a while the fuel could go bad. try getting some type of fuel addittive if this may be the case.
    just a cheap way to dianose is all.
    my two cents
    God gives&takes awayOwn: 1995 Integra/2001 Honda Accord
    Second Pic is too big. Resize then you can put it back. -Pic Police
    snellville
    ok yeah ill try that.. it has been sittin for a while. ill get some stuff tomorrow for it.. thanks -matt
    Quote Originally Posted by n1accord
    my two cents
    SOLD!!!!!
    snellville
    ok everyone... my cars running good and drivable.. thanks to everyone who helped me on it at the meet and at home.... ill let yall' know how it does.. thanks -matt
    SOLD!!!!!
    From the popping you described, either the timing is off, or the inside of your dizzy has came apart and it is not working properly.
    drives a trycicle
    newnan
    how is it running now? did it help that we moved some of the vacuums lines around at all? lmk.
