Results 1 to 13 of 13
Thread: FS: B&W ASW600 10'' Home Theater Sub
    NYC/ATL
    Default FS: B&W ASW600 10'' Home Theater Sub
    Ok, so I built my first home theater a few months ago. I went to the local B&W dealer and they were redoing a showroom with a B&W 600 series setup, so I decided to buy the whole setup from them. Everything was in perfect condition and sounds amazing, but unfortunately the sub is just to small for the room I have it in (plus im a bass head from the car audio world). So I bought an SVS 12'' to replace it and it suits the room better. The B&W is an amazing sub, very clean, and gets decently loud for a single sealed 10''. Like I said this was purchased from Georgia Home Theater where it was used in a demo room, then I used it for maybe 5-10hrs MAX before buying the SVS. It is in perfect condition, 10/10 physically and 10/10 mechanically.
    Here are the specs for those interested:
    The ASW600 is the ideal partner to 600 Series speakers in smaller rooms.
    The 250mm (10 in) driver employs an extremely rigid cone to withstand the considerable forces generated by dynamic bass signals and the integral 150W amplifier, features our Bass Overload Suppression System circuitry to avoid the annoying distortion effects that might normally occur should some unexpectedly loud signal threaten to overload the subwoofer.
    The ASW600 can accept both line level and speaker level inputs and has a choice of equalisation, enabling the response to be tailored to your room.
    Technical Specifications : ASW 600
    Description Active closed-box subwoofer system
    Dimensions Height: 365mm (14.4 in) not including removable spike feet
    Width: 365mm (14.4 in)
    Depth: 450mm (17.7 in) including grille and controls
    Allow extra 50mm (2 in) clearance at rear for ventilation
    Net Weight 19.5kg / 43 lb
    Freq. Response -3dB 26Hz – 33/150Hz adjustable (EQ at A)
    Freq. Range -6dB 22Hz – 40/180Hz adjustable (EQ at A)
    Drive Units Unit 1: 250mm (10 in) dia paper/Kevlar® cone long-throw
    Unit 2:
    Unit 3:
    Finish Cabinet: Black Ash or Sorrento (light oak) vinyl
    Grille: Black Cloth
    Sub Woofer Amplifier Description: Class B
    Power Output: 150W continuous
    Rated Power Consumption: 220W
    Input Impedance: 22kohms
    Signal Noise: 90dB
    Functions: Volume level - Low-pass filter frequency - Low-pass filter bypass - Bass roll-off alignment - Phase 0/180 - Auto sense on/standby
    Inputs: Line In (RCA Phono)
    Speaker Level In (binding posts)
    Outputs: Line Out (RCA Phono, high-passed)
    Link Out (RCA Phono, parallel to Line In)
    Speaker Level Out (binding posts, high-passed)
    Low Pass Filter Active 2nd-order, variable cut-off frequency
    High Pass Filter Line level: Active 3rd-order at 80Hz
    Speaker Level: Passive 1st-order at 80Hz into 8 ohm resistor
    (Response of passive filters dependent on load impedance)
    Here are a few pictures (the grill is included i just took it off for the pictures):
    Retail is $500, I am asking $300
    If you are interested please email me at [email protected] as I do not check this forum regularly.
    Thanks for looking and let me know if you have any questions
    -Jordan
    NYC/ATL
    ATH GA. SRCRX's Avatar
    On the drum set!!
    Damm, that is a VERY highend brand they make some of the best stuff in the world!!
    I've heard a few different setups from them!!!
    NICE G/L
    Dacula GA
    interested in any trades? let me know this would go well with my surround sound setup.
    NYC/ATL
    Quote Originally Posted by SRCRX
    NICE G/L
    Definitely, B&W is amazing equipment, the rest of the HT is all B&W speakers (center, towers, and surrounds). I just wanted a larger sub.
    Thanks for the bump
    NYC/ATL
    Quote Originally Posted by dtmcnamara
    What did you have in mind? I am always open to the idea of a trade, just depends on what you have to offer. LMK and maybe we can work something out.
    NYC/ATL
    Bump, still for sale. Great holiday gift for someone, or yourself
    Islander
    Atlanta,GA USA
    Quote Originally Posted by rollininstyle2004
    Thanks for the bump
    Probs man, I am a b&w guy myself.... that's a nice sub... good price too....g/l with the sale..
    NYC/ATL
    Bump...this would make a great holiday gift for someone
    Suwanee, GA
    bumpin this up for my boy J
    NYC/ATL
    Thanks Tony
    Kinda lame IRL isa2o3's Avatar
    bump, good deal
    NYC/ATL
    Thanks, still for sale guys
