Results 1 to 17 of 17
Thread: OBD 1 jetta question
    Senior Member PD code 805D's Avatar
    black hollywood ga
    Default OBD 1 jetta question
    my car will roll over and die unless gas is applied once you let off the gas it dies.....this is most likely a O2 sensor right? no smoke. good compression. check engine light is on. I can drive the car but it sucks cause i got to rev it at stop lights to keep it running.
    when i hit the gas it JUMPS RPMS very fast. i cant figure this shit out. I wanna get it fixed but im tired of all the money.
    It is a 2.0L 8v How much would it cost to get the 1.8T motor? I wana swapp eventually but i cant find a decent price for my budget. PLEASE HELP!!!!!!!!!!
    need CA$H? I WILL BUY YOUR STUFF OF VALUE.... PM ME WHATCHA GOT!
    Krazy VW chmura's Avatar
    Oct 2003
    Gainesville, GA
    Quote Originally Posted by adarkexit
    4-5 grand....
    somewhere near ur mom...
    a vr6 is more up your price range!
    M Power
    black hollywood ga
    you had a 2.0 single cam ham?
    PM me
    pee...mm'd
    M Power
    If ur going to keep the ABA setup, you should probably check ALL sensors and that o2 sensor. I had a similar problem with my old corrado, a g60 with a ton of mods and the wrong programmed chip!! It ran like poo until i put the right chip in it...
    Is the car/motor stock?
    M Power
    IA KING
    that doesn't sound like an 02 problem, those cars will run fine w/ out them...
    maybe some type of mass air or idle problem???
    black hollywood ga
    those items are so damn expensive though! i need someone with a parts motor or something. Does anyone have a left over motor or parts from the head up?
    $350+ for mass airflow
    $400+ for idle stab. valve <---think this may be the problem.....?
    Oct 2003
    Gainesville, GA
    prob needs both.....
    IA KING
    id just find a good used motor they sell those aba for like 200-500$ complete
    got the mass air..will take a pic in a couple minutes..
    is the idle stab. valve on the throttle body? if so, i couldn't get it off, didn't have a allen wrench set on me to take the TB off
    M Power
    da maas airenheim meuter!
    M Power
    oh yeah, you need to get a hold of a V.A.G 1551, it's a DTC, a scan tool.
    you should be throwing these codes if they are the problems:
    Mass Air code: 2324
    Idle air control: 2231
    idle air control valve: 4431
    if it's the problem, you will get one of those codes, or all of them, who knows...?!?!
    M Power
    black hollywood ga
    Quote Originally Posted by single_cam_ham
    Mass Air code: 2324
    you still got the mass air flow and isv???? I also need a tps if you got it. if you can find those for a OBD I jetta 2.0 1993-1995 year range i will buy those from you now.
    still sitting on my desk at work...
    black hollywood ga
    ok i want them PLEASE PM ME TODAY OR TOMORROW!!!!!!!!
    black hollywood ga
    im goin to pick up my check in like 5 min. I would like to get them by next week sometime!!!!PM me all you info and what you will include for 50$.
    thanks
