Results 1 to 13 of 13
Thread: VAFC fuel controller vs. vtec controller?
    Mi6o
    Default VAFC fuel controller vs. vtec controller?
    i have 04 civic ex...i would like to buy either the apexi fuel controller or the vtec controller but not sure which is better and will give me more hp?! any suggestions or comments on which one i should buy?
    But the Apex-i VAFC controls fuel AND VTEC. So your set!
    Mi6o
    does the VAFC allow me to set the vtec to kick in at whatever rpm i set it to? how much hp would it give me? is it worth it? thanx
    Augusta Ga
    yes it will allow you to CONTROLL VTEC .. as far as horsepower .. it gives 400 +
    93 sol Si
    95 sol S
    95 sol Si
    Your title is funny! VAFC is fuel and vtec controller, so....
    VAFC will only give you so much hp, it all depends on if you know how to tune or not
    Augusta Ga
    Quote Originally Posted by SoSillyyyy
    which it will like i said .. give ya 400 hp + :idb:
    93 sol Si
    95 sol S
    95 sol Si
    RISKY RISKYB's Avatar
    athens
    I wouldnt mess with vtec, in a fairly stock car like yours. You wont see too much gains out of it ,and dont expect to see much more power.
    Mi6o
    thanx for all the help...i guess i'll just wait and save more money and one day i'll boost it..
    also some people think it's smart setting VTEC really low
    Mi6o
    would that cause any problems?
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    Quote Originally Posted by Mi6o
    set it at idle
    convert your GSR to an LS w00ty w00t
    or in your case d17 to a non vtec d16 (yes, vafcII can actually destroke the motor, i was surprised when i found out as well... i think its only on VAFC2 tho vafc1 can only change bore size)
