- civic air ride kit
civic air ride kit
*testing waters* on a 90+ civic EASY STREET air ride kit.
thinking $350 OBO
- EASY STREET AIR COMPRESSOR, PART NUMBER 16450. 12 VOLT, 23 AMPS, 150 PSI, 1.66 CFM FLOW RATE @ 0 PSI.
- KOBALT AIR TANK WITH KOBALT KBA10800AV, #221014 3/8" AIR FILTER. MAXIMUM PRESSUR 150 PSI, MAXIMUM TEMPERATURE 125 DEGREES F.
- 2 FRONT AND 2 REAR STRUTS.
- 4 SMC SOLENOID VALVES, MODEL VXD2130.
- 4 CIRCULAR RUBBER GASKETS.
- 2 SWITCH CONTROL PIECE.
- 2 METAL MOUNTING PIECES.
- VARIOUS WIRING, NUTS, AND BOLTS, INCLUDING NTE R51-1D70-12F AND POLLAK T1 PIECES.
- THIS SYSTEM CAME OUT OF A MID 90'S HONDA CIVIC EX.
- PIECES ARE USED.
- Rep Power
- 20
nice good luck on the sale i really want this would u trade anything 4 it
will it fit a eg possibly, if so willing to trade a system 2 12s and a amp
Takin one 2 the dome
- Rep Power
- 20
BUMP for good price. On your civic, when you had it slammed, would the front be as low as the back. On mine when i slam it, the back tires are on the fender well but the front cylinders bottom out before the tires even tuck
- You may not post replies
- You may not edit your posts
Forum Rules
