trying to figure out if this amp is too much for this sub.
here are the specs on the amp:
Amplifier Type - Dual Channel
Bass Boost
Bridgable
Power Output:
RMS Power at 2 Ohms - 350 W x 2
RMS Power at 4 Ohms - 250 W x 2
Performance:
Frequency Response - 15 Hz - 35000 Hz
Low - Pass Frequency - 40 Hz - 150 Hz
High - Pass Frequency - 75 Hz - 750 Hz
Signal to Noise Ratio - 100 dB
Bass Boost Frequency - 43 Hz
THD at Rated RMS Power - 0.02 %
Dimensions:
Width 14 in. Depth 10.5 in. Height 2.5 in.
Other Features:
MOSFET amp - Yes
The sub is a S10L5 kicker (square):
Dual voice coil - 4 ohms
Sensitivity 86dB
Frequency Response 24 - 0.1k Hz
RMS Power Range (Watts) 50-450
Peak Power Handling (Watts) 900
if it is ok to use this amp with this sub, should i wire it in series or parallel?
thanks
