Results 1 to 20 of 20
Thread: f/s 97 d16y8 with p29 high compression pistons
    Resident Pimp jackdaripper's Avatar
    Default f/s 97 d16y8 with p29 high compression pistons
    This engine has about 150 miles on it as you can tell how clean the pistons and cylinder walls are. I pulled the head only to take pictures of the pistons so yoy would know what your buying. Strongest sohc car I drivin personaly. Had rough idle due to high compression. Should be tuned, I will reinstall head upon someone buying engine so you can see personally the internals. Only reason I pulled engine is I got a great deal on a b series swap that I couldnt pass on. I will split the engine and the head and the engine will not come with injectors or throttle body and a couple of sensors other then that its complete. I also have a 8lb flywheel and a lightweight crank pulley for the engine. Engine has new acl bearings new rings reconditioned rods with arp rod bolts I will take 600 for everything or 400 for short block 80 for flywheel 120 for complete head and 35 for pulley
    "Owning a 9 second import is like coming out of the closet. At first you surprise everyone, but in the end you're still gay!"
    Man-Whore spook's Avatar
    ATL-Shawty
    How much for y8 Intake manifold?
    ATL-Shawty
    Thats with throttle body and sensors right?
    West palm beach
    how much for the head...complete with mani amd t/b,sensors ?
    motor looks good
    Will take 500 if picked up tomorrow
    btw Im keeping the t/b and injectors cause there brand new type r ones and there going on the b series
    TTMFT
    Jonesboro/Stockbridge
    Quote Originally Posted by jackdaripper
    they fit on b series? lol did not know that..
    Augusta Ga
    yea .. you can use tb on any motor .. with slight adjustment ... ( honda motors ) and the injectors for honda were 240 cc,270cc,310cc <- stock injector size for diff honda motors
    93 sol Si
    95 sol S
    95 sol Si
    someone but this shit yo
    NITROUS JUNKIE
    home
    if u still have it friday ill take it
    Ineedcheapshit jankestang's Avatar
    Would you sell the rods and pistons?
    still got it will take 450 cash for engine and pulley.
    I take it that you wont sale the pistons and rods?
    yes for 450
    This
    Great Guy to work with, and fair about price, and good product, bump for you shane, By the way you need any other b series parts, let me know later
    need a passenger side torque mount.
