Results 1 to 16 of 16
Thread: 1963 norton atlas 750 cafe racer
    Broke sullen's Avatar
    Acworth
    Default 1963 norton atlas 750 cafe racer
    ok i have a bit of a problem and im stumped. any help is appreciated. first off, its a 1963 norton atlas 750cc with a BSA headlamp/lightswitch. the bike did not originally come with a battery back in the day, however, to have lights and all you must install a battery. the bike is a positive ground. now, from the alternator, i run through 3 wires to a rectifier. there, the 3 wires are merged into 1 wire. from the rectifier i run to a zener diode. then i am stumped on where to charge at. the other side goes from the negative terminal of the battery to the horn and then to the ampmeter in the headlamp. from the other side of the ampmeter, i run to the lightswitch and to the horn switch. from the hornswitch, i run a signal wire down to the horn. back at the lightswitch, when i move to the first on setting, i power my speedo and rev counter illumination lights as well as the horn switch. then the 2nd on position on the lightswitch will power my headlamp, taillight, speedo and rev counter illumination lights, and 1 idiot light, and the horn. the other idiot light is powered from the rectifier also, shouldnt be a problem with that 1. back to the battery, i run from the negative terminal to the stop light switch, from there to the stop light, then ground there. stoplight works fine. now, where do i plumb in my alternator currnet? i tried to plumb ino the negative with no current and shorted out.
    Belview Insane Asylum
    Shouldn't this be in the motorcycle section?
    Acworth
    sorry. any ideas though?
    I moved the thread, and I wouldn't think you would plumb the alternator current to the negative. Wouldn't it need to go to a positive? I dunno, I'm confused, and don't know a whole lot about motorcycles.
    Acworth
    the positive is to ground. and thanx for moving the thread for me.
    Then I am really confused then.
    Hopefully one of the motorcycle guys in here can help you.
    Acworth
    well who should i talk to then?
    There are a decent amount of guys that come in this forum that know a billion times more about motorcycles than I do.
    Acworth
    well someone has to know about old english bikes other than me right?
    Acworth
    Quote Originally Posted by sullen
    I would think so. Bucky does bike stuff, and there was someone else too that knew a lot abot bikes, but I can't remember his screen name at the moment.
    Acworth
    Acworth
    Acworth
    blank
    nowhere
    sorry i dotn know.
    Acworth
    where does the alt usually charge to?
