Thread: Help! 99 civic ex
    Certified Gearhead JDMef88's Avatar
    Gainsville, GA
    Default Help! 99 civic ex
    ok so like 3 months ago, my car got messed up..it would run for awhile then shut off and the main relay would just click a couple times, oil light and battery light stay lit, as if i was to have the key in the on position...but then when i try and restart it just trys to turn over and just..click click click click...so i got a new ecu, new dizzy, new sparkplugs, new oil pump..and a speed sensor, cause honda said it needed all of this..with the 95$ check up. Ohh and i needed a new fuse box...witch is freaking retarted..whens the last time your fuse box just needed to all be replaced...anways...it magicly fixed my problem...well... for about a week and a half..now it does the same shit.. what could it be??? any other ideas...
    99 civic ex
    5spd
    151k on body
    82k on Motor
    LMK THANKS!
    Wtb 96-00 civic aftermarket struts asap
    LAWRENCEVILLE
    dead battery!
    Gainsville, GA
    my battery is fine.... no clue whats going on..just want my ej8 fixed i did just pay like 700$ to get it fixed..
    check your fuses
    JJSPEC Racing
    if you paid honda 700 id be taking that bitch back with fire coming out of my ass telling them they didnt fix the problem
    -2001 Lexus IS300
    Gainsville, GA
    well honda did not do the maitence my mechanic did...and i wounder why aall the stuff got fixed and worked for a week then shit on me ...its lame as fuck...i just want my car back..i mean damn...no car sucks balls
    If you have a short somewhere it could be just killing the Batt. Try replace the Batt and see if it cranks... Thats Just something to try on your own... ..
    Gainsville, GA
    batt is fine..just got a new one awhile back....who knows...ill give it a run- thanks for the suggestion..
    Quote Originally Posted by JDMef88
    Its a Idea, Also I have seen troubles with ignition switches going bad on Hondas, But your car sounds a little different... But from what I have seen if you had a short in the chargeing system then it would slowly drain the Batt. That causeing you to come out one day and Click, Click,Click.. Thats why I said to put a New Batt. in it... If it don't work then Post Back...
