Results 1 to 16 of 16
Thread: HONDA ACURA YARD SALE
    Alpharetta/Duluth
    Default HONDA ACURA YARD SALE
    I just moved into a smaller house with a smaller garage, and i have realized that i have too many Honda/Acura parts. I am ready to get rid of stuff and get a little bit of money at the same time.
    ****** ALL PRICES ARE OBO UNLESS STATED. PICK-UP ONLY ******
    ........ (404)452-7691 MICHAEL .........
    ------ EG (d-series stuff) ------
    - Alternator $20
    - Timing mount $15
    - Block mount (to block at timing side) $15
    - A/C mount brackets $10
    - DX airbox and tube $20
    - brake master cyl. and booster $20 ea.
    - Driver side lower control arm $20
    - DX Tranny 5spd (needs a bearing) $80
    - DX wire harness (great for a swap) $40
    - DX shortblock (may need bearings, had a slight knock) $50
    - Shift linkages $20
    - Driver Headlight (2dr/3dr) $25
    - CX gauge cluster (182K miles) $20
    - D-series Exhaust manifold $30
    - Civic Exhaust mid section (stock) $15
    ------ DC (B-series OBD1) ------
    - Alternator $35
    - Starter $35
    - Block mount (timing side)
    - P72 GSR powersteering pump and brackets $50
    - Fuel Rail $10
    - Flywheel (stock) $15
    - Timing side mount (rubber is good) $30
    - P72 A/C mount bracket (hard to find usually) $50
    - Pressure plate $15
    - 6-puck clutch disc (very low miles) $40
    - Intermediate Shaft $35
    - Strut bar (OEM Honda) $25
    - Passenger Axle (brand New) $60
    - P72 GSR Oil Pan (fitted for turbo, leaks a little, can be fixed right though) $20
    - LS block and crank #2343775 $80
    - LS exhaust manifold (cut flange-to-cat) $10
    - Custom 2.5" cat-back exhaust (LS 4-door, nice craftsmanship, dented fart can) $50
    ----- EF (d-series OBD0)-----
    - D16A6 Head (ported out) $95 pretty firm
    - PM6 Air intake hose $10
    - A/C fan $20
    - Radiator Fan $20
    ----- EK (OBD2 D-series)-----
    - A/C mount bracket (aluminum) $25
    - Hatch axle-back exhaust (stock) $15
    - 2dr EX Exhaust mid-section (welded-on cat, cut rear flange) $25
    - Hatch cx exhaust mid-section (cut front and rear flanges) $1
    ----- DA (90-93' Integra parts)-----
    - Tail piece (metal body part between tail lights) $20
    - Front crossmember (w/ locator rods and control arms) $20
    - Front Sway-bar $15
    - MORE DA PARTS HERE....
    ----- B16A Parts -----
    - Top Timing Covers (inner and outer) $25
    - 99-00' SI Cams, springs, valves $60
    - Cam gears (stock)
    - 99-00' Exhaust manifold $35
    - Catalytic converter (has 02 bung, OBD2 or OBD1) $40
    -Stock downpipe (welded to mid-pipe section) $10
    - 99-00' SI Exhaust Mid-section $35
    ----- F series Parts -----
    - Alternator brackets $15
    - A/C bracket $15
    - Clutchmasters Aluminum 8.5lb Flywheel $80
    ----- MISC. STUFF -----
    - P54 upper P/S bracket $10
    - Tranny mounts (B-series and D-series) $25
    - Frame rail lower mount (good rubber) $35
    - LS/B16A oil pans (one is for turbo) $25
    - Slave cylinder (for B and D series) $20
    - Universal Catalytic Converter $30
    - Set of 13" steelies (3 tires bald, 1 tire good) $30
    - Set of JDM Toyota 4runner steelies (15" 6-lug chrome, w/ cetercaps) $50
    At Home
    Dibs... on F series flywheel... just wondering if that F series flywheel will fit a F23 motor?
    by my nieghbor.........
    dibs on 6-puck and pressure plate.
    what brand is the 6 puck and pressure plate?
    Banned lsxtreme's Avatar
    is the far can.. welded on ?? and gota picture.. very interested..!!
    Alpharetta/Duluth
    Quote Originally Posted by WhiteAccord
    yeah, if I remember correct all the H and F series flywheels interchange. May want to verify though.
    Alpharetta/Duluth
    Quote Originally Posted by JdMgsrGt35R
    SOLD ALREADY, SORRY
    Alpharetta/Duluth
    Quote Originally Posted by lsxtreme
    yeah the muffler is welded. The exhuast itself would probably cost $250+ to have made.... so $50 is a steal....... LMK
    Augusta Ga
    ls block got internals or no . ???
    93 sol Si
    95 sol S
    95 sol Si
    Banned tippatone's Avatar
    College Park
    Yo if you got the block on friday can i get that???
    DIBS on the b16 cat and the universal one but let me get pictures first.
    Thanks.
    dibs on pictures
    Cmon with the pictures that I need, SLACKER!
    LOL
    +1 for Mike...
    Hope all's well:::
    Alpharetta/Duluth
    Ok guys, the parts you are asking for are at my friends house in L'ville. I will not be able to get to them till this weekend. No pics of the stuff, don't have the time for all that. I work 50+hrs a week, have 2 kids, and a 45min commute to work 6 days a week.
    $30 for the b16 cat ?
    LMK, I'll get it tonight from you friend.
