Thread: WTB: D series All motor parts
    t(-.-t)
    Default WTB: D series All motor parts
    Yep, you heard me. . . Im looking to raise the compression on the litte beast! Im looking for. . . Let me know what you have and I will see what i can do! thanks!
    keep in mind this is a d16z6 Im building. . .
    Cam ( i was thinking Comp)
    Springs, Retainers, and valves
    Manifold (blox or sk2)
    76mm Throttle body
    310cc injectors obd1
    ZC pistons (or something with just higher compression)
    Some type of Header
    Vtec Controller
    And a after market clutch!
    Augusta Ga
    i got some rc 320 cc ..... obd1 .... .. jus used on the dyno .. ... 250 obo .
    93 sol Si
    95 sol S
    95 sol Si
    Dec 2003
    Ive got a bisi motor header that is made for all motor drag. The head you where looking at from Streetstuff on here is where it came from. He told me that head work was done to go with this header. LMK if interested.
    t(-.-t)
    Thanks guys! Im def considering!
    310cc injectors obd1 what type? Saturated or Peak and hold?
    92+ civic use saturated
    You could find these cheap:
    2000-up Celica GT-S 310cc saturated
    If you want Peak and Hold then get 92-96 Prelude Vtec 345cc
    t(-.-t)
    I don't know what the difference is between Saturated and Peak? hell i don't even know what they mean? I know Saturated is soaked, and peak is top. . . but i dont know the car lingo for that?
    NANNERPUSS
    Dec 2003
    winder, GA
    hey i got a brand new dseries axel
    Quote Originally Posted by Mr.MuayThai
    Saturated injectors are high impedance (use high ohm).
    Peak and hold injectors are low impedance (use low ohm), uses with resistor box.
    http://hondaswap.com/general-tech-ar...jectors-30347/
    But if you have 92+ civic, your car use saturated, and if you want to use peak and hold injectors, you have to wire in a resistor box otherwise you will run into trouble.
    Augusta Ga
    my rc injectors are saturated . 320 rc .... well lmk muay .250 an ill ship em to you free .....
    93 sol Si
    95 sol S
    95 sol Si
