Thread: How to bake headlights
    Hear me YET!!! civ97's Avatar
    Woodstock
    Default How to bake headlights
    I'm tryin to fix the fogging in my headlights, and I've tried just about everything. I was recently told to bake my headlights, but I have no clue how to!! So if anyone can help me that would awesome!!! Let me know
    thanks
    not fast enough
    This depends on the make/model of the car. But here's my take on it:
    Take the headlights off the car. You can also take out the light bulbs and the wiring from the headlight housing if you want. Next preheat the oven to about 200 degrees. Put the headlights on a baking sheet and put them in the oven for about 15 minutes. This is what's called "baking" the headlight. The process melts the glue that holds the glass front housing to the plastic backpanel. I guess you can push the housings together make sure they seal well. When the headlight cools down the glue should've sealed the headlight better.
    If that doesn't work you can always pry apart the front of the housing from the back after you've baked the headlight. Then you can put more of the special 3m glue on the side of the housing, unite the housings and re-bake them.
    Low-n-Slow iEvo's Avatar
    Gnett
    its no big deal. i did it with my 350z lights along with my evo's lights. if worse comes to worse drill a small hole in the bottom of the headlight and that usally works about 90% of the time
    stick it in the oven lol
    Fayetteville/PTC/Carrollton
    The yellowing of your headlights wont be helped by baking them you have to wetsand/polish them. Do a google search for wetsanding your headlights, i did it with mine and they came out much better.
    ^ well he said that it was yellowing IN his headlights, so im assuming that he wants to bake the suckas open and clean the inside part of the lens?
    is better than you..
    Somewhere you're not
    i think he means condensation inside the headlights
