(price dropppppppppped)
clarion drx9575rz (head unit)
Touch-n-GO Motorized Sloping Console Detachable Face
High Visibility 8-Color Dot Matrix Large LC Display
RDS Reciever, ® FM Reception System
Controller for Optional DSP/EQ, AMP. & TV Tuner Modules
Capability to Read CD TEXT Data from Clarion Compatible CD
Z-Enhancer with 3 Adjustment Modes
CeNET with Balanced Audio Line Transmission and Dynamicn 8-Times
Oversampling Digital Filter and Dual 1-Bit D/A Converters
Zero-Bit Detector™ Mute Circuit
4V/4-Channel RCA Line Level Output with Fader Control
4V/2-Channel Non-Fade RCA Line Level Output with Volume
1 Optical Digital Output
i am selling it for 125 obo
Rockford Fosgate P1L-212 system
* Loaded with two 12" Punch Stage 1 woofers
* Single 4 ohm impedance
* High-flow Venturi air system
o Larger port cross-sectional area
o Longer port length
o Minimum noise and distortion
o Maximum acoustical output
* Precision enclosure construction
* High density automotive-grade carpeting
* Custom molded end panels with embossed RF logo
* Computer aided subwoofer, port, and enclosure design
* Large gauge, gold-plated binding post connectors
* Internally wired with RF Connecting Punch speaker wire
* Dimensions: 16.5" L x 34" W x 15.5" H
Rockford Fosgate Punch 501S AMPlifier
1500w
MA Audio M1900XE
1000W Mono Block High Performance Amplifier
* Mono Block High Performance Amplifier
* Subsonic filter: 20-50Hz
* 1 x 500W RMS @ 4-Ohm Mono
* 1 x 1000W MAX @ 2-Ohm Mono
* Dimensions (HxWxL):2" x 10" x 13"
* Variable High/Low Pass Crossover 50-250Hz
* Variable Bass Boost 0-18db @ 45hz
* 3-Way Protection Circuitry
* Full MOSFET circuitry
* 2-Ohm stereo stable
* High/Low level inputs
i am selling it fo 100 obo
pm me
