Results 1 to 25 of 25
Thread: SHIFT LINKAGE PROBLEM
    Southside of The Jungle
    Default SHIFT LINKAGE PROBLEM
    I have a 90 civic with a b18 my shifter is retarded if you put the car in 1st u can move it all over and the car will still be in first gear and when u go to second it seems to get stuck so u have to force it down the shift linkage jus is like on frre roam it goes into all the gears just it wont stay over that way if you out it in the gear imma put up the pics they not so good tho so sorry
    sorry bout how big the pics is resizing rite now
    Southside
    I have a B-Series shift linkage, just the 2 individuals, and if it isn't that have you checked your transmission fluid?
    middle ga
    no bushing in your stablizer bar
    Attached Thumbnails Attached Thumbnails -hpim0248-jpg
    Well having it welded does creat a problem bro.
    Quote Originally Posted by GSRteg
    i kno having it welded creates a problem but damn if drove my car u would be like wtf i and the stabilizer bushing where can i get one of them from
    warner robins
    honda and while your putting a bushing in there get a new intake too
    JJSPEC.COM
    I can't really see much from the pictures but perhaps its hitting the exhaust?
    Quote Originally Posted by d16_turbo
    dont no body like the intake i bout the car like dat and thats the very last of my problems
    middle ga
    aw, com'n give him a break...it's a central vacuum system!
    middle ga
    did you check that bushing yet????
    It looks really close to the cat-converter, when you push it over to 3rd from 2nd it rubs doesn't it? Making it hard to get in, I had same problem before & had to have my exhaust slanted downwards a bit.
    Norfolk, VA
    <---Click it.
    Quote Originally Posted by Whiteboy
    Not necessarily, my stock linkage didn't scrape my exhaust after getting the exhaust tilted but when I put the AVID shift linkage in the counter weight thingy on the shift linkage hit my exhaust really bad so I just sawed it off. It's still very close to hitting the exhaust, less than .25 inch.
    who knows.
    numbered in importance
    1.no bushings on the stabilzer bar.-biggest problem , will fix alot.
    2.get a bitch bin instead of that fucking bolt. will also help alottt
    3.looks like u got under your car without jacking it. if so. buy some suspension and drop where u cant or the shit is a gonna look like shit.less your ridin 20's
    4.there is a bushing in middle of the shifter inside where u bolt the shifter up to if thats not there then youll have a lil extra play.help a lillll
    5.fix that leak your under carrege looks like a little smashed water melon.
    get a new intake youll gain like 20 hp. lol jk i dont know how much hp youll gain but sure will make it easier to look at.
    Quote Originally Posted by thinkskater
    wat is bitch bin and i did jack my car up it jus so low i couldnt jack it that much or it would onli be on one wheel
    middle ga
    in the first pic you have a bolt...toss that shit and get what is in the second pic...thats what thinkskater is talking about....and i seriously think that if you put a bushing in that stabelizer bar like i said on the 4th post of this thread alot of of your problem will go away.
    Attached Thumbnails Attached Thumbnails -bitchpin-jpg   -bpin2-jpg
    Quote Originally Posted by japan4racing
    wat is that lil shit called and where can i get it from
    middle ga
    most ppl call it a bitch pin i have a handfull of them laying around. where do you live?
    its called a spring pin, you can get from honda/acura for about 3-5 bucks, but the reason why your shifter is acting ghey is because whoever installed the linkage either forgot that there is supposed to be a bushing on the end and that a little pin is supposed to be there and not a bolt, or they just dont care about you lol. order some shifter bushings from somewhere for bout 12 bucks and find a linkage pin then have a nice day
    middle ga
    Quote Originally Posted by SoSillyyyy
    i have been trying to tell him this for the duration of this thread...no one cares to listen..i even provided a pic so he could see what im talking about
    lol i stay in riverdale and i got my ear to the street man i heard ya do nopi got linkage bushings i dont feel like waiting on ebay
    it was built by a mexican so pretty much ni### rigged its all good i do it too
