Results 1 to 11 of 11
Thread: help with installation
    Apr 2003
    Suwanee,GA
    Default help with installation
    I am going to install an amp and sub in my 02 accord..the only problem is ive never installed it before but have seen friends do it..the only question i have is does anyone know if it is hard to wire the amp toi the stok headunit..i have the high/low adapter with rca outs and also where should i wire the remote wire.. i was thinkin to antenna lead..any help appreciated..
    Don't Hate On Somethin Better Than Yours.
    [email protected]
    BYAAAAAAAHHH!!! threehundred's Avatar
    22" off the ground
    The remote wire is so you can have a wired remote control to your amp. Did your amp not come with a remote control?
    05 Chrysler 300 - Kitted on 22s
    06 Quad Cab Dodge Ram 1500
    Cumming, GA
    I always thought the "remote" wire was the short name for the "remote turn on" wire. This "should" cause the amp to power up once you turn on the Head unit.
    If it is indeed an amplifier remote control, that would be a new one for me. I have seen some bass control knobs (silly knob) that will run off what looks like phone cable.
    Missin My 20's! accordon17s's Avatar
    F.I.L.A.
    You can splice the remote wire into the blue/white wire coming off the adapter or u can wire it to a switch that connects directly to the battery if im not mistaken, i would splice it into the blue/white wire tho if i were you.
    Jan 2003
    John is correct.
    The "remote" lead off an AMP is for the remote POWER on/off. It senses when the HU turns on and let's the amp power up. It should always be connected to the "remote" output on the back of the radio. If no "remote" lead available on the HU, you should probably connect it to the switched power lead that powers the radio that way it gets power at the same time the radio does. You don't want to hook it up to a constant power source.
    22" off the ground
    LOL. I was kidding. I forgot about this thread until now.
    What, none of you have wired remote controls like on old school tvs? I've got a 20ft wired remote control on my system. lol.
    Banned flysi00's Avatar
    hmmm...hold on, almost had it...damnit!!!
    Quote Originally Posted by threehundred
    Jan 2003
    I was hoping you were. YOU know better....
    Apr 2003
    Suwanee,GA
    thanks guys for all this info..im installing it tonite if i have more ?s i will post em up
    [email protected]
    make sure your ground is good thats where most peope go wrong when putting in their amps
    IA MEMBER YokotaS13's Avatar
    saudi arabia
    and get a real headunit. your going to hate the quality on teh line converter
