Results 1 to 14 of 14
Thread: FS: Modded 1988 Ford Mustang LX 5.0
    Certified Gearhead lemansz's Avatar
    Default FS: Modded 1988 Ford Mustang LX 5.0
    $7500
    [email protected]
    For sale: 1988 Ford Mustang LX. Fresh red PPG paint, showing 80,987 miles. This car has a 5 speed T-5 manual transmission. Here is a nice example of a typical Fox body project car. Someone has put a lot of sweat and tears into building this into a nice little performance package. This car surely has $20,000+ in aftermarket parts and labor. It needs a good owner and a little bit of TLC to really bring this project from the final stages into finished product. This car stands tall and the slick red paint pops! I have described this car to the best of my abilities from my own inspection. I did not build this car. I have tried to find the flaws in this car and have done by best to take a picture of all of them. Please see the list of modifications that I found on this vehicle and view my collection of large detailed pictures to answer any questions. If you would like any more information please to not hesitate to email me and I will answer them to the best of my ability!
    Performance mods:
    Long rod 308 ci v8 engine
    GT40P heads
    Crane Roller Rocker arms
    GT40 intake
    65mm throttlebody
    65mm EGR spacer
    24# Fuel injectors
    73mm C & L mass air meter
    Adjustable Fuel pressure regulator
    1 5/8 “ Mac Longtube headers
    2.5 inch Mac H-Pipe
    2.5 Inch Flowmaster 2 chambers
    2.5 inch Stainless Tailpipes
    190 LPH walbro fuel pump
    Ram HD clutch
    Fresh T-5 transmission
    Kirban short throw shifter
    MSD Blaster TFi coil
    9 mm Ford Racing black spark plug wires
    Polyurethane HD Motor mounts
    3.55 rear end gear
    Suspension/Brake Mods:
    Steeda Lowering springs
    Koni Yellow Struts and shocks
    SS machine lift bars
    Caster/Camber plates
    M2300k 13 inch front 5 lug brake kit with 2 piston PBR Cobra Calipers
    5 lug rear disc brake conversion
    1999 17 x 8 inch Cobra Wheels
    MISC:
    275/40 17 Nitto 555R Extreme Drag Radials
    2.5 inch fiberglass cowl hood
    17 inch Cobra spare tire and wheel to fit over 13 inch front brakes
    Adjustable clutch cable
    Polyurethane HD motor mounts
    New AC Evaporator core
    New Engine starter
    Aluminum Heater core
    New Ford Cooling fan blade
    New Ford Radiator Overflow tank
    New Headlights
    New Blinker lights
    New clear corner marker lights
    New Steel outer door handles
    New Door hinge pins and bushings
    Interior:
    1993 Opal grey GT interior
    Seats, dash, door panels, 1993 style seatbelts with shoulder belt
    1989 GT 140 mph speedometer
    Door lock actuators work
    OEM Ford Tape deck
    Wheels/tires/brakes
    Interior:
    Engine:
    Flaws:
    LAWRENCEVILLE
    nice clean 5.0 if it was a coupe i would be all over this! but i dont know about the $20,000+ in aftermarket parts and labor seemes a little high
    Quote Originally Posted by silversol
    thanks alot!
    As for the invested mods...Add it up man!!
    I havent personally but i bet its right around 20, retail prices + labor
    Building a shortblock, parts, labor,machine work, assembly $2500
    heads, cam, intake, TB, EGR, MAf, inj, roller rockers, plus labor 2500 parts plus labor at LEAST 1000
    Full exhaust, headers, h pipe, mufflers, tailpipes, labor, muffler shop to weld tailpipes $ 1000
    m2300k 13 inch Cobra brake kit alone is $2000+ new
    thats over a 10 hour install $2500
    HD ram clutch plus install $ 400
    3.55 rear end, and install $ 450
    Full interior swap... out of a 1993 mustang. with 1989 140 mph speedo thats over 1000 in parts used, plus labor to do it. $1000
    R134 AC conversion with new heater core and evaporator, labor $ 500
    cowl hood 400$
    New headlights and markers $ 200
    steeda springs, and struts and shocks.. labor 200 + 350
    full repaint, with underhood painted and clearcoated, as well as door jams and trunk jams - $1750
    17 inch cobra SVT wheels.. + tires.. $1000
    17 inch spare tire was $250 USED!!!!
    I get like 15,000 kinda ball park.. just off the top of my head
    oh and BTW the car is located about 30 miles east of atlanta
    Certified Gearhead 95stangs's Avatar
    how much r u asking?
    1995 Mustang V6
    Cardomain
    For Sale
    Myspace
    Man, I would like to take that off your hands. Not interested in a trade are you?
    Dunwoody/Sandy Springs
    that is fucking nice. are you interested in a trade? where are you located? pm me!
    4rd WHAT? SicStang03's Avatar
    Sandy Springs/Dunwoody
    I just nutted in my undies.....
    Quote Originally Posted by coolcat View Post
    NO SHIT AT ALL I JUST HAD MILK AND A COOKIE. I DIPPED THAT BITCH AND EVERYTHING, SORT OF LIKE I DID MY NUTS INTO YOUR MOTHERS LOOSE VAGINA.
    That......would be my bad. Sorry.
    Is this still for sale? I'd like to check it out. Where exactly are you located?
    Thanks for the compliments bro! and the bump!
    The car actually has a pretty nice paint job. All of the trim and moldings were removed prior to painting. The engine was removed and the engine bay was painted AND cleared, which goes above and beyond most jobs. The spare tire well was not painted, nor was all of the interior removed and the interior painter, nor was all of the glass removed and the door window hardware removed and the inside of the doors painted.
    The lower door moldings were not removed prior to painting because they are discontinued from Ford. 50-75% of the time they get damaged and look wavy after they are removed. If they were to be damaged and the car was missing 1 or both door moldings, how would the car look then?
    There is such a thing as point of diminishing return.
    That would cost 2500-3000. Wouldnt that be overkill on a decent daily driver that I was only asking 6500-7000 for? Seems to me yes.
    That was one of the nicer repaint jobs I have ever seen on a mustang.
    As far as the mods.. add them up..
    I can get between 15-20k off the top of my head with out trying very hard.
    The only upgrades I can think of would be a more expensive rotating assembly, an R block, a blower or turbo, a tremec and a big fuel system.
    but then the car woudl fetch 10-15 k IMO.
    Running the car down, without ever seeing it.. is pretty lame. Posting some .05 megapixel out of focus, random pic of a car you saw somewhere that couldn in fact be nicer than this one is even more lame.
    This car is 19 years old. I will say its one of the nicer fox body cars you will see. I will not say it is a show car or the nicest fox body you have EVER seen.
    a tru OG,.. ask somebody
    May 2001
    lake lanier/cumming
    how many miles does the shell accually have? since the speedo was switched over whats the real millage?
    Jimmy Blair II
    www.Pinnacleracing.com
    01 Tahoe w/ 'sclade stuff
    99 Grand Cherokee
    IA's Instigator
    Statesboro
    Bump for a good/respect seller!
    I see that you are ''30 miles east of atlanta''. that puts pretty close to each other. could you PM me the location of the car, I would like to come see it. thanks.
    Sorry she has been sold...
    Let it go for 6500
    thanks folks for the bumps.. and compliments
