Thread: help please
    catch this 4dr primetimeciv's Avatar
    huntsville al,
    Default help please
    ok this is what i got. 91 honda civic with a dohc zc and when we got it started every thing was ok till we find out that it wont go over 3000 rpms. so i put a new cap and rotor button and still the same so please can some one help me please?
    huntsville al,
    can any one help?
    itakepictures
    changaroopouch
    are the spark wires in correct order from the dizzy?
    Macon
    could be a bad ecu
    Land Rover LR3 HSE
    Belview Insane Asylum
    Quote Originally Posted by allmotoronly
    could be a bad ecu
    That's what I was thinking. Is it throwing a check engine light?
    Low-n-Slow iEvo's Avatar
    Gnett
    ur car is in limp mode, which means there is a major sensor that is either unplugged or went bad. check all the major stuff and ull find it
    huntsville al,
    ok the code is a 4 and no check engine light and i have three diff computers and i checked all the sensors and there all good? sooo i dont know what to do and im about to sale it.
    Hwy 315
    obd0 code 4 is your Crank Angle Sensor... which is located in the distributor. There are two sensors in there. One is your Ignition Output sensor... which will have a blue wire going to it (off of the small connector on the dist.) And the other one (should have three slide connectors) is the crank angle. They take about ten-fifteen minutes to replace and aren't expensive. Although your best bet is to find one at a junkyard. I don't think Advance auto or anyone carries them anymore.
    obd0 CAS' are notorious for going bad, and this would def. engage the artificial rev limiter you're seeing while in "limp mode."
    -Check to make sure all your connections are night and tight on there (should be 3 slide-on types)
    -if the connections are tight, and you don't see an excessive amount of corrosion; then it's def. time to change it out. (which is a piece of cake)
    Good luck man
    -jonathan
    [/URL]
    Jesus Christ is my Savior
