Results 1 to 14 of 14
Thread: Do i need to Dart my B20???
    Banned tippatone's Avatar
    College Park
    Default Do i need to Dart my B20???
    I am dropping a B20 into my integra and i wanted to know if i needed to sleeve my block when i went B20/ vtec. And of course i will get Dart sleeves if i need to do it. As you guys should know a B20 isnt made for vtec, my boy has a B20 vtec and he was runnin so hard that the block had scars on the walls. Just wanted to know what you guys thought.
    02 WRX patrick4588's Avatar
    warner robins
    dart makes aluminum blocks and heads. darton does sleeves. but unless you are going turbo, i wouldnt worry about it. and even if you are going turbo, if you keep it under 300whp you should be fine
    middle ga
    if he had scars it was not becuase of how hard he was running..it was becuase of how fucked his rings were..obviously had oil problems. on one hand you have the motor apart so you might as well build it...but on the other hand its a b20 with a vtec head and all motor...just slap it together untill you get enough money saved to boost a gsr
    College Park
    i have a ls motor also,they are better, i was going to use to b20 because it is complete. and boost not, a b20 the ls will be better for that. the only reason the ls is not an option is for the fact it needs pistons and needs to be cleaned/resurfaced
    Stan The Man TallGuy's Avatar
    Dacula Ga.
    what are yuor plans for the B20/vtec?? are you going to boost it or stay N/A??
    College Park
    thats a great question. i plan to stay N/A, although boost seems to be tempting, that is why i keep th LS block around just in case
    Proud Mr2 Turbo Owner
    Subherbs
    depends on how high a compresssion you gonna run, and if you gonna run a supercharger or turbo... on a turbo majority of people sleeve their block once they are 14+psi to be safe
    1996 4dr Integra
    1992 Mr2 Turbo
    RPM = Ruins People's Motors
    College Park
    So what compression do you think i should go for, i hope to pull around 180 to 190 hp with a all motor build.
    for an NA app;ication no sleeving is neccesary up to 250whp.
    see it done with no problems
    turbo, anything over 10psi i would sleeve on a b20
    College Park
    Ok thanks for the help
    Cambodia
    I don't believe ctr pistons would work in a b20 either, unless he's talking about "ctr style" pistons. Ctr is somewhere like 81mm, while a b20 is somethin like 84mm.
    JDM TYTE AnthonyF's Avatar
    if that is ur teggy in ur sig...beautiful color. good luck with the build!
    The Carbon Fibered R6
    College Park
    that teggy is gone (R.I.P.) , but i got a 94 shell and part two is under construction.
    werd.........
    atl
    i had a b20 vtec on my white 94 teg b20b block with gsr head
    and lol not the most reliable thing yo and def not rev happy block
