Thread: Prelude Stuff / Audio Stuff
    Here and there Hulud's Avatar
    Omnipresent
    Default Prelude Stuff / Audio Stuff
    Here I have some stuff that NEEDS TO GO!
    Come get it now!
    92-96 Prelude Spoiler with brake light - $30
    Pace Setter 92-96 Prelude Header - $45
    Custom Front 92-96 Prelude Strut Bar - $30
    Koiiler Subwoofer & Box - $60
    Val for President
    Just add water OaTmeaL's Avatar
    Specs on the sub?
    OF*C
    OEMFitment Crew Memeber 02
    Future: OEM fogs, Koni/GC setup, and Volk RE30 wheels.
    Omnipresent
    i believe this is it:
    160 oz. Double stacked Ferrite magnet
    Oversized rubber surround
    Power handling:800 Watts Peak, 400 watts RMS
    Vented 4 Layer Dual 4 Ohm Voice coils
    Diameter: 2.5" Voice coil
    Nominal impedance: 4 ohms /per coil
    DC resistance: 3.2 ohms each coil
    Frequency range: 20 Hz-1.5 kHz
    Fs: 41 Hz
    Qts: 0.6360
    Qes: 0.7209
    Qms: 5.4047
    Vas: 26L
    Xmax: 11.9mm
    Sd: 0.0346m
    Mounting Depth: 135mm
    Mounting Hole Diameter: 250mm
    SPL: 86.54 dB 1W/1m
    i will double check in the morning
    Val for President
    Omnipresent
    Val for President
    IA Junior Member acura_dude's Avatar
    Dawsonville
    demensions on that strut bar?
    LIL WEAV
    Omnipresent
    it will only fit on a 92-96 lude
    Val for President
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    Is the strutbar the CUT 5th GEN BAR? If so, take 20$$?
    Does it come with all mounting screws/bolts?
    Omnipresent
    no its a custom bar its tube piping as the bar so its stronger than those ebay pieces of crap
    Val for President
    Getting there admedlin's Avatar
    Columbus
    how long was that pacesetter header used?
    Omnipresent
    Quote Originally Posted by admedlin
    ~5k miles
    Val for President
    still got the sub and box im interested pm me...
    Omnipresent
    pm'd
    Val for President
