Results 1 to 11 of 11
Thread: FS: LOTS of Honda/Acura/Turbo stuff
    Default FS: LOTS of Honda/Acura/Turbo stuff
    BadlanzHPE, Inc 3 inch electronic exhaust cutout (brand new) - $180
    Right rear ABS line shield off 96 LS - $5
    Right rear ABS sensor cover off 96 LS - $5
    Alternator bracket off GSR - $20
    Passenger side black housing corner for 98-01 Integra - $10
    Block/tranny brackets for b-series motor - $10 each
    Right rear brake caliper off 98 GSR (can be fixed or used for parts) - $20
    Right rear brake shield - $5
    Breather chambers (1 from LS, 1 from GSR) - $25 each
    Breather pipe off 98 LS (#9 in the picture) - $10
    Front bumper piece for 98-01 Integra (maybe 94-97), some overspray - $20
    Front bumper support for 98-01 Integra (maybe 94-97) - $40
    Front bumper support pieces for 98-01 Integra (maybe 94-97) - $20
    GSR crank pulley - $40
    GSR dipstick - $5
    Integra Radiator Fan (shroud was trimmed on one side for turbo clearance) - $30 (A/C fan is sold)
    Integra Passenger Seatbelt - $15
    GSR crank (spun a bearing) - $50
    B-series header brackets - $10 each
    Stock LS internals (~60,000 miles) - $50
    Stock LS rear sway bar - $40
    Complete set of LS shocks (good condition) - $60
    Oil pans, 1 LS, 1 GSR (GSR one has a dent) - $20 each (1 of the LS ones is sold)
    Integra radio pocket - $20
    Rear block covers (1 LS, 1 GSR, but I think they are the same) - $15
    LS transmission case (seems to be fine) - $20
    B-series water pipe/thermostat housing/oil cooler - $60
    Set of 4 17" wheels with universal 4 lug pattern (1 is cracked/bent, but can be repaired) - $150
    GSR windage tray - $20
    LS windage tray - $20
    94-01 Integra window trim, some overspray, needs a few clips - $50
    "Cool car" less.
    Anti-Nutswingers Crew - Member # 001
    Hey Check PM asap!
    Northwest Georgia
    i could use that GSR windage tray!
    Quote Originally Posted by SPOOLIN
    OK.
    "Cool car" less.
    Jonesboro/Stockbridge
    hey i might know someone that'll get that w7..i'll let you know
    lawrenceville
    what is the flywheel for?
    Banned DB8-2NVY's Avatar
    In My BaCkYaRd!!
    hey man any trades lmk wat ur looking for
    ATH GA. SRCRX's Avatar
    On the drum set!!
    Quote Originally Posted by 3kgtdrvr
    B-Series
    "Cool car" less.
    Default Honda/Acura stuff for sale
    Quote Originally Posted by DB8-2NVY
    What do you have?
    "Cool car" less.
    OOOOOP.
    "Cool car" less.
