Results 1 to 24 of 24
Thread: Saturday Night
    Senior Member Capt._Ron's Avatar
    Canton
    Default Saturday Night
    I will be driving to G-nett tonight since technically im on vacation. I was curious as to whether or not anyone was running since I will be up that way. I would like to get some runs in against 300-350 hp car now that I have changed a couple of parts on my car. (Last time was just embarrasing car would run at 15 psi and just sucked).
    -Ron
    I Have a Cool Car chnco's Avatar
    Jan 2003
    Marietta, GA
    take your slow piece and burn
    Summit Shiloh Crew
    Allen C.
    [email protected]
    S13's are the FUTURE.
    -IA MGMT is inappropriate.
    Canton
    Quote Originally Posted by chnco
    Oh yea well you take your $60,000 piece of yellow shit at let it rot because your too scared to bring it out ha ha
    Super Dave Z U L8R's Avatar
    Roswell
    i was there saturday looking for some runs. i didn't see you though. will u be out next saturday?
    Dave
    b00bies!!! Wal-Mart's Avatar
    Everywhere you want to be...
    I came rolling through looking for some runs but everyone is a pussy up there. Someone needs to call INS on most of those fucking beaners up there and so all the cool folks have their spot back.
    Rock the 40oz GTScoob's Avatar
    GA Tech
    Ron, give me another 2-3 weeks to get everything sorted out with my new motor and I'll hand you your ass. I havent raced a 240 in a couple of years, with ~240whp I would normally end up a half car ahead of them from a 60mph pull.
    02 WRX Sport Wagon
    Canton
    Quote Originally Posted by Z U L8R
    Dave
    I did see you there. I was sitting on the ground right next to mike (orange and green miata) when you were looking to run. I have the gray 240. The guy with the fd was right there too.
    Roswell
    oh......well shit, lemme run ya =P
    Roswell
    i'll turn off my boost controller and run off the 9psi wastegate spring, should be like 250ish hp
    Canton
    I definately though about it. Even though you were at 400ish. But i figured i would have gotten dominated. I should be in the 300 range.
    GA Tech
    Quote Originally Posted by Capt._Ron
    300 to the wheels?
    02 WRX Sport Wagon
    lawrenceville, georgia, USA
    Quote Originally Posted by Wal-Mart
    can i be part of your cool club?
    Canton
    Quote Originally Posted by GTScoob
    300 to the wheels?
    Yea. I finnally got the intake and fuel sorted out. Its like a never ending battle though because it spikes 20 psi but wont hold. I end up at 16 or so. Could that be solved with a better boost controller?
    Roswell
    possibly
    is 20psi above the turbo's efficiency though? what turbo's on it?
    Canton
    It has a ball bearing t28 that came stock on a 2000 model s15.
    i might be up there just to watch
    ive never gone up there, i might check it out...
    Roswell
    s15 turbo should be round 280 @ 15-16psi, that turbo should hold 18psi no problem, and if you had a boost leak unless it was very very small, as soon as you boost it'd start bucking/coughing/acting a fool so i don't think it's that. still double check your coupler clamps and replace any dry rotting/cracked couplers. if your wastegate actuator arm is adjustable try taking a little slack out of it also. if you're running a manual boost controller then it may be actually set@ 16psi but is just spiking to 20. manual bc + internal wastegate = spike.
    best bang for the buck = old school GReddy Profec. it's just like a mbc as far as adjustability but it holds true /w no spike the whole way across, plus you can set the gain higher to have the turbo come in sooner. i would definately not recommend assuming it's set to 16 but spiking at 20, so in compensating setting the base to 20 and having it spike to 22-24. it's cheaper to get a good boost controller than another motor.
    what injectors? engine management?
    Weekly Gwinnett/Junciton Meet
    can i joing? I would like to run as long as cars, like mentioned, are in 250 range. My new coupling should arrive by friday.
    Roswell
    i'll run @ 9 psi
    i just hate going to bp then not running anyone grrr!@#!@#!@#!#
    my coupling prbly isn't gonna make it on time...time for some retro reinforcement on the old one...if i blow it..oh well. I don't mind running handicap lol.
    Canton
    Thats it exactly. I just have a mbc so im guessing that is what causes the spike. I have looked at the profec B.
    Roswell
    cool, yeah the ole school one is easier to set than the new one but once you figure the new one out you're fine. they're both great for the money
    good luck man, hope to see you saturday
    dave
    Roswell
    Dave
